Home > General & Technical (L663) > Roof Bars |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 189 |
Hello All,
Quick question regarding the LR original roof rail cross bars.... are they designed to be left in place once fitted to the roof rails or are they easily removable to allow you to refit as and when required? Also, can they be placed anywhere along the roof rails or can they only be fitted to a predetermined fixed point? Cheers |
1st May 2021 7:08am |
Thanks for your reply and the video link
Seems a bit strange that the part of the video that shows fitting and locking the cross bars is not actually on a defender and doesn't use the same type of mounting bracket. I have a Discovery Sport and the cross bars I have on this come from an Evoque and they fit fine, however they will not fit a Defender as they use a clamp fitting (rather like that shown in the video). Looking at the clip of the Defender roof with the cross bars mounted then subsequently removed it does look like there are specific 'slots' in the roof rails where the cross bars fit, which suggests you don't get a choice of where you can place them? |
1st May 2021 10:17am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
Fixed points see, instructions,
http://accessories-instructions.landrover....r/G2409809 No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
1st May 2021 12:10pm |
Right, thought so. Not exactly a quick release fit, so I'm guessing once they are on best just to leave them on!
1st May 2021 1:41pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
I haven’t noticed any increase in fuel consumption leaving them on the car and the only time I get any noise from them is when I crack open the sunroof, the noise disappears if you fully open the glass panels though. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
1st May 2021 2:23pm |
Just look for the Thule system, You could even make the sliding plates longer so they can sit every where on the rail.
https://www.defender2.net/forum/topic76190.html No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
1st May 2021 2:36pm |
GreenMonster Member Since: 30 Sep 2020 Location: Virginia Posts: 77 |
If you use the non oem Thule bars and feet you can locate them pretty much anywhere you want as long as you avoid the gaps where the track opens up in width.
2nd May 2021 2:56am |
thanks for all the replies and advice.... seems Thule bars may be the way to go
3rd May 2021 10:03am |
you're welcome ! No Mud flaps for my 90.!
3rd May 2021 11:12am |
