Home > Maintenance & Modifications > Stuck brake drum hub |
When I have had to do this it begins with a lump hammer and tapping all around the drum to loosen up the drum on the studs and from the shoes. After that a cold chisel and lump hammer tapping from behind and working around the drum. It takes time but eventually the drum begins to move across the shoes and along the studs. The trick is methodically working your way around the drum.
Yes it is usually a lying on your back and taking your time job If you feel you need something "extra" you can warm the drum (not the backing plate) a little and this sometimes helps release the drum from the shoes. If you can retract the shoes as much as possible before starting the job so if there is a wear lip on the inside of the drum the shoes will clear it. There are puller tools out there to do this too if you want to or can afford them. For me the tapping method has never failed even if it has taken time. Good luck |
30th Apr 2021 2:07pm |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
Thanks, always a bit wary of damaging the casting but its gotta come off some how!
Looks like i have a morning of tip tapping away! |
30th Apr 2021 2:36pm |
I can understand that, but be gentle and most importantly persistent.... The casting is much stronger than you think just resist the temptation to let out your inner HULK...
30th Apr 2021 2:46pm |
30th Apr 2021 2:49pm |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 368 |
Had the same problem Tuesday of this week. A Fabia that had been stood still since January had one rear drum stuck solid. Lots of progressive persuasion with various hammers and a cold chisel eventually brought success. Took the best part of an hour, but that also included removing the alloy wheel which had secured itself to the drum. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
30th Apr 2021 4:13pm |
