Home > Technical > Cigar Lighter socket
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
Hi all,
I've recently bought a 2014 tdci defender, and I'm pleased to say that most of it works...
But the cigar lighter socket in the dash is dead. I've checked the fuse, and that's fine.
My next step is to start taking the centre console apart, I thought I'd ask on here before I started:
Is this a common fault? (a forum search hasn't brought up much in this space).
Do the unit's break/die, or have I likely got a wiring fault to resolve?
I presume I do have to take the centre panel out to remove the unit?
Any help appreciated.
Jon
Post #900367 28th Apr 2021 1:43pm
My guess is the electrical connector has come off the rear, and yes the centre panel has to come out but you shouldnโ€™t need to disconnect other electrical plugs at all.
Just take out the torx screws and release it.
If you have one, a multimeter it would be ideal just to check for power and continuity of the ground as well.
It isnโ€™t common for the lighters to fail, but if the lighter socket is at fault then reopening is the only option.
As I said, you really need to check that power and ground is present.
Hope that helps, you would be best removing the radio / HU before taking it out also to avoid any damage too. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #900372 28th Apr 2021 2:28pm
jpboost
OK, nice to know it's not a common fault.
Will have a look for loose wires and if that doesn't work, I'll try to find my multimeter in the lockup!
Post #900380 28th Apr 2021 3:36pm
Good luck. Thumbs Up No Guts, No Glory.
Post #900393 28th Apr 2021 4:44pm
jpboost
All done.
I ended up removing the radio (and mounting cage) in order to get the centre dash panel off.
All connectors to the cigar lighter had been unplugged. They were nice and secure when I refitted them, so it seems unlikley that they'd fallen off. I can only assume that someone disconnected them, or forgot to reconnect them at somepoiint.
Anyway, it all works fine now, so I'm happy.
Thanks all.
Jon
Post #900480 29th Apr 2021 7:25am
Good result, yes, that does sound the most plausible reasoning for their disconnection. Thumbs Up No Guts, No Glory.
Post #900537 29th Apr 2021 12:21pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
I had exactly the same issue on my newly arrived 90. Haven driven it a couple of weeks, I wonder if it's the vibrations that makes them eventually fall off?
Post #902463 10th May 2021 8:50pm
Could be, especially if not replaced firmly. Iโ€™ve got a blue sea 12v socket on mine which I mush prefer. Thumbs Up No Guts, No Glory.
Post #902464 10th May 2021 8:54pm
Ianh
Vibrations eventually make everything fall off on a defender Rolling with laughter its all part of the fun of ownership
Post #902467 10th May 2021 8:57pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Rolling with laughter Rolling with laughter Rolling with laughter Rgds.
Chris
Post #902470 10th May 2021 9:15pm
jpboost
It could be, but the connections were very secure when I refitted them, and certainly were as secure as some of the other connections back there.
My gut feeling is that someone disconnected it, or forgot to reconnect it while doing something else. But I'm still baffled as to what that might have been. There's no evidence of the dash ever having been apart, so no idea why anyone would be 'in there'.
Post #902536 11th May 2021 9:49am
it is entirely possible that they were overlooked during factory assembly and nobody ever noticed until you did.
Post #902544 11th May 2021 11:30am
jpboost
Very true.
It's not the most noticeable of faults!
Post #902550 11th May 2021 12:32pm
nitram17
[quote="jpboost"]All done.
Thanks all.
Probably a security measure to stop thrives using a tracker blocker in the lighter socket.
Post #904030 20th May 2021 7:22am
