Home > Off Topic > Painting a garage floor.
Page 2 of 2 <12
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I used some poleurathene epoxy (as it was inside/outside (small part of the garage floor goes outside)
Was a case of cleaning well the floor (opening up the surface with a Diamond grinder (hired one)
Then fill the gaps with a caulk that was ok for the epoxy, smoothing that (gaps were expansion points in the floor)
filling small cracks with the above.
Wetting the floor and letting dry for a couple of days
Sweeping
Paint the first coat (thinned down a little with thinner)
wait till next day, paint the next coat (no thinning)
Run out of paint close to the end and then quickly get more)
Finish the floor
Wait for 48 hours to it to dry.
I have dropped jacks, had tow trucks drop there loader part on it, all not a scrape (that I can see) and as others have pointed out, just a bit of water, and its clean again.
Cost was prob about £1000 (paint was 600, hire of machine 200, and then the caulk was prob close to 150) and some new paint brushes as the ones I used could not be cleaned totally.
Size about 150m2 (just to give idea) Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #900274 27th Apr 2021 7:53pm
jst
Personally I would paint it if your putting it in yourself, just float it as it dries. Mines been perfect for 12 years since doing this. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #900323 28th Apr 2021 7:50am
Avelingporter
Ive just finished mine last weekend. It is the second garage ive done with the same system. Five litres of Leyland hard wearing floor paint. Available from B & Q, enough for 2 coats of a single garage. The previous garage is now 14 years old and going great. no chips or flaking. Cheap and easy.
Post #900340 28th Apr 2021 9:32am
jst
Sorry skim not float! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #900390 28th Apr 2021 4:39pm
Matt110
Did you need to do any prep before applying or literally just brush down and Hoover and then roller it on?
Post #900446 28th Apr 2021 8:40pm
Page 2 of 2 <12
