Home > For Sale & Wanted > [Found] Green top injector or injectors
Jez676
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Just had some work done on my td5 and found that it has an odd black injector!!
It’s been on there for ten years but from reading on here they shouldn’t be used as they run at different pressures.
Anyway I’m after a fully working injector or a set if anybody has some they want to sell?
Kind regards
Jez
Post #900200 27th Apr 2021 10:59am
dcc
United Kingdom 2005 Defender 110 Td5 CSW Alpine White
hi Jez
do you still need 1 injector?
Dan
Post #900305 27th Apr 2021 11:33pm
Jez676
Hi Dan,
Yes found one locally thanks Dan👍
I still don’t understand how the 10p one was working in my car!!!
Post #900671 30th Apr 2021 8:53am
geobloke
It would have been interesting to see whether there was a slight mis-balance in the cylinders due to the black injector. Good to know that in a pinch you could use a black top to get home... Rolling Eyes
Post #900677 30th Apr 2021 9:20am
dorsetsmith
TD5 injectors are either green top (1700psi) and black/blue top (1500psi) at the tip
Codes in the ECU must been fun or not Whistle over fuelling the black top injector Exclamation
Post #900679 30th Apr 2021 9:29am
