Home > Off Topic > Just bought a Discovery 1 |
Worth a photo or two of some of the best?
https://twitter.com/overlandbound/status/1386726897548238854?s=20 |
26th Apr 2021 5:37pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1319 |
I've bought two Discos in the last 6 months or so for use as trailer tow trucks at our sailing club.
The 1st is a Disco 1 300tDi Auto with 9 months MOT for £1200. Amazingly good chassis and just a bit of welding around the rear door panels. Turned out to be a Jap import which probably explains the chassis condition. The second is a TD5 Auto Adventurer 7 seater Limited Edition. 220,000 miles with no real history for £1400. This one has 11 months MOT. Drives really tightly and everything works as it should. Even still has the factory fit drop down DVD player in the roof for the rear passengers and a CD autochanger under the driver's seat. Good rear chassis with no terminal rot so far. The rear air suspension has been replaced with coils, but not a problem as we don't insure the vehicles for road use. Both are really too good to use as trailer hacks and it got me thinking about cashing in my expensive Jeep Wrangler and running old Disco's!! I think the trick would be to just keep running one until something expensive lets go, or it fails the next MOT on a string of issues, then break it for spares. To answer your question Blackwolf on why the chassis seem to rot away at the rear, I don't really know. I wonder if it is because the front end tends to dry out quicker after getting wet from the engine/transmission heat and perhaps the areas around the engine and power steering benefit from frequent built in protection from oil leaks Can't think the cross section is thinner at the rear, but who knows. |
26th Apr 2021 5:41pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17473 |
But it is much smaller and nothing like as capable. And it was designed by the Great Satan aka McGovern. |
26th Apr 2021 7:22pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 793 |
Looks the same as my ES Premium - 98k miles and a good chassis Click image to enlarge BORG - Bucks & Oxon 4x4 Response Group |
26th Apr 2021 7:23pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
I’ve had all discoveries bar a d3 (never liked)not sure why people are down on the D5, ignoring this latest one going to optional low range, stupid idea, we use our d5s hard just as much as the past.
Each have good/bad features that I would wish carried forward, but the d5 certainly can eat the journeys better my 300tdi I think could do hardcore off road the best and the d4 probably had the best van design (but the rrs was a better cat in similar form factor) Mike |
27th Apr 2021 9:46pm |
