Home > Puma (Tdci) > CV Joint (Puma) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8078 |
You can replace either shaft or cv independently. Sorry don't have mpn to hand. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Apr 2021 8:22pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 625 |
Not on a Puma you can’t, the CV joint and Shaft are one piece, so you have to replace the whole lot.
The Puma cv joint / shafts are slightly stronger than the pre Puma ones so you would be downgrading if you fitted the earlier Td5 / 300tdi front shafts with removable cv joints. |
23rd Apr 2021 6:35pm |
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 |
I got mine from Ashcroft.
23rd Apr 2021 7:23pm |
Err, yes you can. Cheers
23rd Apr 2021 9:46pm |
So...
- How do you remove the shaft from the knackered Cv as they have a square section snap ring instead of the wire snap ring pre 2007? - once you have removed the square section snap ring shaft which is designed not to be removed from the cv joint, which cv joint do you replace it with as they aren’t available separately for the Puma, and pre 2007 ones don’t fit as the Puma shaft uses roll formed larger diameter splines as opposed to the pre 2007 cut splines. |
24th Apr 2021 12:22am |
yes you can.
Click image to enlarge Top right and this clip |
24th Apr 2021 7:03am |
Well done for linking to the 300tdi workshop manual not the Puma one.
And also for showing a pre Puma snap ring which isn’t present on the Puma shaft. |
24th Apr 2021 7:57am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
My copy of the Puma WSM suggests you can.
Click image to enlarge Rgds. Chris |
24th Apr 2021 9:09am |
OK then look at pages 146 and 147 07 puma work shop manual But you will find that i has been pasted and copy form the Tdi 300 work shop manual
Good luck https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7?e=ddUECt |
24th Apr 2021 9:22am |
That will be the Puma workshop manual that shows a Salisbury rear axle along with other parts cut and pasted from earlier manuals.
As someone who has worked extensively on the Puma for the past thirteen years including rebuilding three of them from the ground up instead of reading the manuals online. Clearly Dorsetsmith you have not as you wouldn’t be posting pictures of a pre Puma wire snap ring for a start. And you haven’t provided a part number for the non existent separate Puma cv joint without shaft. I think I have two Puma Cv/shafts in my skip still I may smash apart to prove it. |
24th Apr 2021 10:22am |
have replaced cv from post 2007 land rover defender and had on trouble at all
24th Apr 2021 10:31am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Oldowner - no need to be rude pal, if you want to do that to people who are trying to help then go elsewhere. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Apr 2021 11:46am |
Silver110 Member Since: 10 Jun 2020 Location: East Sussex Posts: 49 |
So seems like this maybe just another thread without a definitive answer!
Dorsetsmith, what CV joints have you purchased and used in the past. and do they come with the ring? I’ve never done it before but I’m pretty certain this can be done. After all we are talking about a defender whose design hasn’t changed in 30 years. Oldowner, what makes you so adamant that it can’t be done when Dorsetsmith has said he’s already done it? What part do you think is not doable? Not having a dig just curious? Thank you both for your help. |
24th Apr 2021 10:04pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17458 |
I have a pair of original Puma front shafts/CVs which I took out to replace with Ashcroft HD items. If I can find them I'll see if they can be split in the traditional way - it was my understanding that they can but I haven't bothered to try before.
24th Apr 2021 10:11pm |
