![]() | Home > Puma (Tdci) > Black Smoke on Full Throttle |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
Has it been tuned at all? Sometimes people can go over the top.
The other thing is to check the intercooler and turbo hose for wear or splits. Where abouts in Zambia are you? We were out there a couple of years back before covid and looking forward to getting back when things settle. Longer term plan is to ship my 130 out to Southern Africa for a wander. ![]() |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
Mine was a bit smoky under load. What cured it was a combination of two things...
1. Replaced injector seals. Existing ones had failed and were leaking. I think this was throwing off the diesel/air mixture somehow? Not sure exactly how, whether the ECU was overcompensating fuel or the leak was throwing off the mixture as air escaped from the cylinder. 2. Fitted catch tank. When the injector seals were leaking it was venting gas/oil via the rocker cover breather which goes back into the inlet and burns blue/black. Disconnect the positive crankcase pressure return hose from the inlet temporarily and see whether it improves the situation > 110 XS Double Cab |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Hi Camelman, I am in Lusaka. Have been for many years. You can always use me as a Lusaka contact when you do pass by. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
I did fit new genuine injector seals and new bolts and torqued and turned them as required. How else could I diagnose leaking injector seals: tapping noise or blowby from the oil filler cap? 1995 300tdi Defender 90 P/UP
Excellent thanks. Will see what the world looks like next year ![]() ![]() |
Moffett Member Since: 08 May 2018 Location: Sligo Posts: 69 ![]() ![]() ![]() |
I had this smoke steam for a few days. Cleaning the MAP sensor (which was totally clogged) sorted it. It is a 5 minute job.
No, it's back. Vastly improved, but it is still happening in 6th. The search continues.
