![]() | Home > Technical > Correct Servo |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 545 ![]() ![]() |
Think its a type 80.
this link may help you http://expeditionlandrover.info/dual_brake_conv.htm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 647 ![]() ![]() ![]() |
It’s not a type 80, it is stc442. And the reason your brakes are poor is visible in the photo!
Patagoniang Member Since: 18 Apr 2021 Location: Coyhaique Posts: 3 ![]() ![]() ![]() |
Thank you both for the prompt response. STC442 it is, which has been replaced by STC4322.
Yeah, the leak is pretty evident and the servo does not work at all. I just wanted to make sure I was ordering the correct part as shipping from the UK is quite expensive. Cheers. |
