![]() | Home > Wheels & Tyres > How to clean alloys? |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Thanks for all the recommends.......before i order one of them, what do you think of this, I only mention it because its half price currently and i can pick one up today?
https://www.halfords.com/motoring/car-clea...hgreferral 2008 TDCi 2.4 XS CSW |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2240 ![]() ![]() |
This original wonderwheels is quite acidic, so you have to be very careful with it . The bilt hamber wheel cleaner, and those that have attempted to copy it perform the same or better but with much reduced risk of damage to the wheel coating. |
Pace Member Since: 19 Mar 2021 Location: Somerset Posts: 85 ![]() ![]() ![]() |
Not watched it as I personally cannot stand the bloke, but from the title alone I can tell you that oven cleaner is too aggressive. In answer to the original question, I wouldn't put anything that wasn't designed for cleaning alloy wheels near anything you remotely hold value to. Many products are just too acidic, so a neutral PH is important as others have stated. Even standard TFRs are known to corrode wheel nuts and were subsequently banned from the detailing bay of many a dealership. If you have the slightest nick in your lacquer, you will soon have flakes coming off as the harsher chemicals will continue to track underneath long after you think you washed them away. Any product by Bilt Hamber is a good bet for its intended purpose, other than that Autoglym is usually a novice-proof range. |
