Home > For Sale & Wanted > [Wanted] Land Rover Series PTO |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
I appreciate this is a little OT but I'm aware many members have series vehicles.
I'm looking for a series PTO assembly, specifically the selector unit and the rear output assembly. Had a lucky find today and would like to complete the kit and fit to my 80". Click image to enlarge 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
14th Apr 2021 8:22pm |
Good idea, will give him a call!
Lovely 80" you have there, I may need to ask for some measurements of the outer guard piece in due course please. I have the inner cover but not the outer. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
15th Apr 2021 9:05am |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 750 |
Repro covers are available from Rob Maud.
You’re lucky to have the rear cover, I think they were often taken off to put the shaft on, then lost! |
15th Apr 2021 9:32am |
I doesn't look as though the rear cover was ever fitted as there is still packaging present on the wing nut!
I saw Rob's guards, they cost as much as I paid for the rear PTO, pulley, guard and prop!! That said, not an easy thing to fabricate and they do look lovely. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
15th Apr 2021 10:11am |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 |
There is one advertised on Facebook Market place at Chesterfield, search '' Series PTO'' and you should find it. Richard
Either a 90, 110 or 130. Discovery 5 |
15th Apr 2021 2:40pm |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 |
Have you got the prop shaft? If not where do you plan to get one?
If you do have one what length is is compacted and fully extended please? Many thanks 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
15th Apr 2021 3:07pm |
Do you think you could PM me a link please? It's possible that it is listed in a group I'm not a member of I suppose? (Can't see it when I search for Series PTO). EDIT - found it 1985 127 V8 Build Thread Series 2 109" Series 1 80" Last edited by Shroppy on 15th Apr 2021 3:52pm. Edited 1 time in total |
15th Apr 2021 3:16pm |
Re propshaft, yes it came with one for a 109 which unfortunately is no use, so I plan to have a new one made at a local specialist when the time comes. I'm happy to measure extended/compacted lengths if it would be helpful?
Otherwise I believe CKD shop sells them. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
15th Apr 2021 3:18pm |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1286 |
The PTO shaft for a 109" is a rare bit of kit, especially if it has the centre bearing and mounting bracket. It might fetch you good money if you decide to sell it.
I have a spare 80" PTO shaft, but I've never looked at selling values as I'm usually too lazy to advertise stuff, never mind package it! If you can get repro(?) ones from CKD shop that would be favourite I reckon. I may even have the control unit for the top rear of the gearbox. I know there's some NOS stuff in a shed, but once again I haven't looked lately. I got a little bored with SI stuff, years ago. Sometimes if someone local who I know turns up, I will let something go but otherwise maybe my heirs will have to sort it out.... Here's a pic of a PTO on the back of a 109" SI. Click image to enlarge And a few early 80" PTO guards looked something like this: Click image to enlarge |
15th Apr 2021 4:13pm |
And just for fun (as someone often asks!) here's the difference between a Land Rover rear pulley and a Fergie one:
Click image to enlarge And I've just noticed the control units in the pic. So they must be somewhere! |
15th Apr 2021 4:18pm |
Slideywindows, I'll drop you a message, perhaps we can work something out.
The 109 PTO prop looks like a 130 rear prop to me, no signs of a centre bearing or mounting bracket..... 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
15th Apr 2021 4:19pm |
109" PTO shaft. Two pieces.
Bearing in the middle, on a bracket. Can be seen in this photo: Click image to enlarge |
15th Apr 2021 4:24pm |
In which case, I have the rear prop but not the centre bearing or the front prop as it were... I need to touch base with the chap I got them from incase he finds any other related bits. 1985 127 V8 Build Thread
15th Apr 2021 4:28pm |
If I remember correctly, the rear section is the same as used for the PTO on 88" Land Rovers, so is more easily found.
It is the front section and bearing that is tricky to find. I hope you have success with that. |
15th Apr 2021 4:31pm |
