Home > Puma (Tdci) > 90 Sliding windows, rear door, rear and alpine - Window Tint
roche1800
Can someone help help me with window tinting, what is the correct procedure?
Some say windows have to removed however I am not keen as the window seals are disturbed and any damage to the body/panel.
What are your thoughts please?
Anyone had it done?
Thanks in advance.
Post #898198 14th Apr 2021 1:32pm
X4SKP
Hello roche1800
Yes... all out (all 9 rear windows) Tinted and back in.
For mine, the decision was driven by the best approach to Wrap the Roof.
Absolutely will be down to the quality of shop that get's the Job, mine was done just prior to buying it,
so I got to inspect all areas...my Interior was also 'uplifted', so seeing a good job, strangely underlined
the 'it's ok to change what is less than ideal or you just don't like the look of.
Shop around and get confidence first... ideally with someone who has had their hands on a Defender
Good Luck SKIP
Post #898203 14th Apr 2021 1:50pm
glpinxit
I’m interested in the answer to this. When I tinted the windows in my early TD5 I removed all the glass to do it (and didn’t tint the alpine lights). Removing the sliding windows necessitated drilling out all of the rivets holding the frames in. Now I want to tint my late model TDCi and will be getting a professional to do it. Mainly this is because I have assumed that the sliding windows will have to be tinted in situ because the later frames are bonded in and not riveted. I don’t have the skill to cut the film invisibly in situ.
I’ve not heard of pros removing glass before applying tinting film regardless of whether it is bonded, retained by a rubber gasket or sliding so I assumed it was always done in situ. Cheers, Guy.
Post #898283 14th Apr 2021 7:34pm
