![]() | Home > 130 > 130 Side Steps |
Smyles_ Member Since: 26 Aug 2018 Location: Copenhagen Posts: 513 ![]() ![]() ![]() |
Can't say I've ever seen those in particular fitted but judging by the short mounting bracketry I'd hazard a guess that they'd probably sit just below the sills like here:
![]() Click image to enlarge Stuart ![]() Cummins 130 Build Thread 04 110 Double Cab - Black (gone) 58 130 Double Cab HCPU - Cairns Blue |
J_Defender Member Since: 31 Mar 2021 Location: Milton Keynes Posts: 44 ![]() ![]() ![]() |
Thanks for the reply, Stuart, I'd agree that they look to be mounted a little higher as per the image you posted.
Could do with comparing them side by side with other options to get a proper idea, really. |
I'd rather just have rock sliders with protruding steps that replace the sills rather than that setup. just looks cumbersome to me.
![]() Click image to enlarge OR ![]() Click image to enlarge Stuart ![]() Cummins 130 Build Thread 04 110 Double Cab - Black (gone) 58 130 Double Cab HCPU - Cairns Blue |
I may actually have just found a 130 with those steps installed here
They seems to have removed the sills entirely, maybe so you can get your foot under? ![]() Click image to enlarge It doesn't however support my initial theory with the short bracketry... maybe the product photos are at an angle that they look short or, they extend them with that truck having a lift?? Stuart ![]() Cummins 130 Build Thread 04 110 Double Cab - Black (gone) 58 130 Double Cab HCPU - Cairns Blue |
That's really helpful, thank you very much!
Not keen on the bare-sill look personally. I would also tend to agree with you, looks like they have extended the brackets in this image ^ |
I just think it looks a little "unfinished" in this side profile image:
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 330 ![]() ![]() ![]() |
I quite like these. Anyone knows if they're off the shelf of custom made, and where they can be purchased? Defender 130 HCPU Td5 MY2000 |
To be fair, they look like standard rock sliders with chequer plate inserts, but I could be wrong...
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3345 ![]() ![]() |
Shire fabrications do 60mm rock/tree sliders to fit 130 for reasonable money. I have them on the 110 and getting some made up for the 130. Mine need to be 6 inches longer than standard 130 sills however.
![]() Click image to enlarge ![]() Click image to enlarge ![]() |
They were custom made as far as I'm aware. Can't imagine it be that hard for you or a shop to replicate - just a angled cut to the end of the tube. ![]() ![]() Cummins 130 Build Thread 04 110 Double Cab - Black (gone) 58 130 Double Cab HCPU - Cairns Blue |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 861 ![]() ![]() ![]() |
Would be interested to see the 130 sliders camleman, can't see them on their website? 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
I'm guessing it'll be these in 130 flavour:
https://www.shirefabrications.com/rock-and...60mm-tube- ![]() Click image to enlarge |
I understand what would make you say that, but I think you're wrong: with standard rock sliders the tube isn't offset / angled downwards but parallel to the "sill"-part.
True, but I think it would be more convenient and probably cheaper if I could just purchase a set, hence the question. Defender 130 HCPU Td5 MY2000 |
