Home > Maintenance & Modifications > Defender Heated seats element OEM
90GTR
 2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
I'm looking for front seat heating elements (backrest and base) for BOTH front seats, however must be with OEM LR plugs. Can anybody advise? They're for a TD5, but I think they TDCI plugs are the same?
I've seen Exmoor trim (which I think I'll be otherwise ordering) have them and Defender upgrades although they are slightly dearer.
Any other companies I'm missing?
Not after the britpart ones which are different, just need them as OEM as possible as I won't be changing the plugs.
Post #898182 14th Apr 2021 1:38pm
Co1
If you get non OEM ones, Martin on here will sell the OEM plugs and a bit of flex for you to joint in. The OEM pads are about 3 times the price of non OEM.
Post #898244 14th Apr 2021 6:35pm
90GTR
Thank you and noted if it applies again or the below doesn't materialize....
In my eagerness to get the solution solved, I bought the exmoor trims full kits for the pair and I'm assured they're in stock... circa £115. Rolling Eyes
Post #898302 14th Apr 2021 9:22pm
Waeco are good, I use them and you can use them with factory switches just identify the pre heat wires and not use those those and just use the standard heat setting wires.
That’s what I did, I’ve heard the Waeco ones are warmer that factory but can’t comment myself. WeWillWin🇬🇧🇺🇸
Post #898312 14th Apr 2021 9:52pm
