Home > Puma (Tdci) > PUMA - Access to Steering Box Adjustment |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17466 |
Remove the wing.
10th Apr 2021 2:22pm |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 |
There is a hole in the radiator cowl plastic adjacent to the adjuster. I pop the top of the cowl off, stick a spanner through the hole to slacken the locknut, then use an allen key socket on a long extension fed down from the top, at the side of the intercooler hose/ radiator cowl, onto the allen adjuster bolt in the steering box.
You can see the hole in the image below Click image to enlarge |
14th Apr 2021 12:20pm |
