![]() | Home > Puma (Tdci) > grease for propshafts |
is there a specific type of grease that should be used to grease prop shafts ?
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 ![]() ![]() ![]() |
I use lithium based grease on my propshaft nipples
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Yes, I tend to use this Castrol version:
http://www.opieoils.co.uk/pdfs/castrol/cas...-tubes.pdf |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
I use a tube from unipart.
I think most high pressure grease will do. Probably a lot more important to do it regularly, than the specific grease used. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
cheers guys, has to be castrol (part of bp), will order some tomorrow and grease regularly
