Home > Technical > Fuel gauge not moving |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 528 |
You'll have to take out more than 1/4 before the gage in a 110 tdci moves
10th Apr 2021 7:55pm |
james.works Member Since: 19 Jun 2019 Location: dax Posts: 17 |
The gauge reads zero with warning light and alarm on ignition no matter how much fuel is in it. There is no signal to the instrument I.assume.
10th Apr 2021 8:03pm |
check chasse loom gray plug in engine bay
10th Apr 2021 8:17pm |
Connectors in the engine bay look ok, nothing untoward I can see anyway. There are two cables not connected to anything, just swinging in the wind! They are white/brown and black/grey, what are they supposed to be connected too, any idea?
Thanks |
11th Apr 2021 7:44am |
Click image to enlarge Click image to enlarge wire colour GO = Green -( orange tracer ) YP = Yellow - ( purple tracer ) C1040L-pin 31---------- GO------- C0376-pin 6 ---to-----C1759-pin 6-------to----- C0115-pin 1 C1040L-pin 8-------------YP--------C0376-pin7 ----to-----C1759-pin 7-------to------C0115-pin 2 C1040L = instument cluster plug C0376 = engine bay plug--------------- C1759 = engine bay socket C0115 = tank unit plug Last edited by dorsetsmith on 11th Apr 2021 9:17am. Edited 3 times in total |
11th Apr 2021 8:21am |
Thanks! Do you have a link where I can download them, these are a bit hard to read, eyesight not so great these days!
Found it, unfortunately it doesn't help me as I have no idea what it all means or where to begin diagnosing the fault! https://dokumen.tips/reader/f/defender-my1...g-diagrams Last edited by james.works on 11th Apr 2021 9:23am. Edited 1 time in total |
11th Apr 2021 8:48am |
11th Apr 2021 9:13am |
You my have open circuit wiring between interment cluster and fuel tank unit or ( open circuit fuel sender )
Multimeter is good friend for continuity circuit testing and also Click image to enlarge Last edited by dorsetsmith on 11th Apr 2021 9:50am. Edited 1 time in total |
11th Apr 2021 9:24am |
OK, I have a meter and I can handle some basic continuity testing, what do I test though?!
11th Apr 2021 9:42am |
work your way down from instrument cluster plug continuity testing two wires
chasse loom is harder as one end has plug in engine bay but other end for fuel sender is at top of the tank ( but in past I have removed loom conduit from chasse loom at rear end wheel arch and find the two wires and continuity testing between this point and the engine bay plug if find that all is ok with wiring from instrument cluster plug to rear end wheel arch you all need drain fuel tank and lower tank down so you get to the plug at the top |
11th Apr 2021 10:35am |
Great thanks, which two wires am I testing?
11th Apr 2021 11:07am |
green wire with orange tracer and yellow wire with purple tracer test individually with separate retune wire as find that one or both wires are open circuit. test each part of the circuit individually i.e. Instrument cluster plug to engine bay plug in order isolate faulty part of the wiring loom
11th Apr 2021 11:38am |
I have continuity on both of those cables from the instrument cluster all the way to the fuel sender unit, the instrument panel is not faulty as I have tested it in another puma. So it could be the sender unit itself or is it possible that it is software related as the panle is not the original one paired with the ECU?
11th Apr 2021 2:09pm |
its not software .
how much fuel in tank ? ruffle resistance reading are you getting |
11th Apr 2021 3:51pm |
