![]() | Home > Td5 > TD5 occasionally not igniting |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5848 ![]() ![]() |
To clarify. Are saying that the engine turns over and doesn’t start, or are you saying that it doesn’t turn over?
The wildest man in town Member Since: 25 Oct 2020 Location: Boras Posts: 37 ![]() ![]() ![]() |
It doesn't turn over.
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 ![]() ![]() |
time to overhaul the starter motor
repair kit of ebay less than £20 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 226 ![]() ![]() ![]() |
Also check the smaller exciter wire on the starter motor, quite common for a loose connection. Had two in last couple of weeks at work. It’s just a normal 1/4” spade, that becomes loose. Hope you manage to get it sorted,
Ashbyandy 👍 |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Is it single clicks or multiple clicks?
Multiple is voltage issue, single is starter issue. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Check starter motor as above, and also check that the fuel pressure regulator isn’t leaking on from above.
