Home > Puma (Tdci) > 2.2. and 2.4 power difference.
Page 1 of 3 123>
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
Some feed back please. I have a 2010 2.4 and a 2014 2.2 both 110. The 2.4 Is very noticeably more powerful. It pulls well through all the gears. The 2.2 drives fine but does not have the same punch. Do the PDFs on the 2.2 become blocked and if they do, how can it be cleaned.
Post #896795 8th Apr 2021 7:59pm
Dinnu
Are they exactly same? Both hard tops or both CSWs for example?
Are they both running same tyres, same tyre pressures? Do they have similar milage?
If dpf is clogged, it should get detected by the pressure difference sensor (bolted to the bulkhead, behind coolant reservoir). It should throw the mil light on.
Sorry, maybe a stupid comment... but I very interested on what others have to say as well. I am becoming a paranoid when it comes to dpf, probably due to the fact that I cannot do motorway miles to help clear it up. My only option is to drive like a maniac in 2nd or 3rd gear! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #896799 8th Apr 2021 8:15pm
Howard
The 2.4 is a 110 utility and the 2.2 a 110 tipper . Both the same size tyres. 2.4 on BF all terrain. 2.2 on BF muds.
Post #896811 8th Apr 2021 8:35pm
Howard
Post #896812 8th Apr 2021 8:36pm
Fat Cog
Not sure about the DPF being blocked but having had 2 2.4's & a 2.2 I would say I didn't notice much difference, if anything the 2.4 felt more lower down grunt & the 2.2 marginally quicker on motorways etc. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #896820 8th Apr 2021 8:46pm
Co1
While neither are exactly what you would call aerodynamic, the tipper with roof rack and mud tyres would add some drag and weight so I’m not that surprised that you see a difference.
Post #896846 9th Apr 2021 5:09am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
The dreaded DPF.....
DPF’s are only really suitable for vehicles that do long runs as they need to regenerate and burn off particulates. Not really ideal for most Landys.
I would try adding a DPF fuel additive when you only have a quarter tank of fuel and take it for a long blast up the motorway, at least 50 miles. And do this every year to try to prevent problems.
I avoided the 2.2 DPF variant specifically, as I only ever do short runs.
To overcome this burn off, many manufacturers use adblue systems, they still have inherent problems but work better for lower mileage use. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #896847 9th Apr 2021 5:34am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I think you are being unfair. Owning a 2.2 for 7 years and having been on this forum for at least as long, I struggle to recall any significant issues with DPFs. Mainly the odd query on how they operate and a very occasional warning light issue.
Post #896950 9th Apr 2021 2:08pm
I think I'd have to agree with you there, DPF no issues... but don't mention EGR...
Post #896982 9th Apr 2021 3:51pm
Co1
I have never had DPF issues (EGR is a different story). However I do have a few friends that only really do short journeys and they have perpetual issues.
Post #896991 9th Apr 2021 4:11pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I had an issue where my dpf was doing an active regen far more frequently than I thought it should be.
Turned out to be a leak between the turbo and dpf.
But the dpf technology itself seems to be pretty rock solid from my experience.
Post #897023 9th Apr 2021 5:25pm
DEF4
While both engines produce 122BHP, the torque is different - 2.4 has 221 ft lbs but the 2.2 has 265
Post #897131 10th Apr 2021 6:08am
JOW240725
No experience of the 2.4, but when I remapped my 2.2 it made a huge difference. Are you sure the utility isn't mapped? James
Instagram @suffolk_rovers
Post #897135 10th Apr 2021 6:23am
You wouldn't happen to have the torque curves for them would you?
Post #897136 10th Apr 2021 6:26am
That's not right - the 2.4 is also 265 ft lbs. Darren
Post #897138 10th Apr 2021 6:28am
Page 1 of 3 123>
