Home > Off Topic > Best way to graft fence posts together? |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2009 |
I’m assuming these are 100mm wood fence posts. Cut existing and new post at a sharp angle that covers about 18 inches . Wood glue and Clamp them together and then use 75mm number 14 screws thin sides into thick sides. If old post and new post are the same size and you cut accurately and not out of square then you should get a joint that’s strong and not that visible.
Ps. Marking cut on both sides and using a circular saw makes it easier to get a straight and square cut. Alternatively you can get square box section post joiners as well as angle iron ones. |
7th Apr 2021 5:50pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3677 |
Here’s Ian, yes 100mm posts.
7th Apr 2021 5:56pm |
If you have a trolley jack it’s easy to get the posts out with the big lump of concrete attached without any need to dig
7th Apr 2021 6:07pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
With a graft it will add strength if you drill a big centre hole in both and dowel them. Flat or angled doesn’t matter
You could simply buy post extender joints Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
7th Apr 2021 6:33pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
cut it off, dig it out of the concrete if not already rotten and drop new post in existing concrete 100x100 hole Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Apr 2021 7:04pm |
