Home > Technical > Genuine spot lamp loom
Procta
I have been recently installing the main loom, but i have came a cross and problem,
maybe you lads can help me, as its stopped me from going any further with installation Rolling Eyes
the instructions say this
but no blue and orange to splice into on the dash harness? Either something is missing or my dash loom is from a earlier model or something, but this has put the brakes on.
Any help there lads? The instructions are pretty hit and miss here. My dad looked at it, and he just backed away, after he saw the instructions. He said that's pretty sodding poor that, no pin or wire colour to go into. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #895813 3rd Apr 2021 11:35pm
rallysteve
Blue and white wire in cavity 1.
Post #895824 4th Apr 2021 7:03am
Romadog
Yep Blue white. Ive fitted a couple of these looms and not had a problem with instructions. Would have to check back in my library to see if the same as yours.
Post #895981 5th Apr 2021 9:39am
Procta
Thanks fellas, is there a fault with the instructions or am i just miss reading here? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #896104 6th Apr 2021 12:24am
dorsetsmith
No post 07 blue / orange wire at ins cluster is main beam pin 27 on plug
pre 07 blue / white wire at ins cluster is main beam pin 1 on plug
Post #896167 6th Apr 2021 10:55am
Procta
no blue/ wire on the harness on this model, Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #896477 7th Apr 2021 1:35pm
dorsetsmith
Green /white wire pin 2----------------------- red / slat gray wire pin 11
Post #896497 7th Apr 2021 3:01pm
Procta
thanks fella, i will have another go at it on friday, as i do have a to change the dash over for replacement,
when you mean
do you mean try both wires? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #896498 7th Apr 2021 3:07pm
dorsetsmith
use plug pin out above and work out wire colour for pin 1 plug
Post #896499 7th Apr 2021 3:24pm
