Home > Maintenance & Modifications > Defender steering box woes.
jimmyvonk
United Kingdom 2004 Defender 110 Td5 CSW Epsom Green
2004 TD5 LWB
On the last MOT I received advisories for too much play in the 4 bolt steering box - fair enough.
The box is not leaking and seams to work ok but the middle dead zone is a bit wide.
Problem - the adjuster is seized - lock nut comes undone with the adjuster screw, and no way to get enough purchase on them without stripping the adjuster with all the crap in the way.
So... if I take the box off - do you think I will be able to free it off with some heat etc when I can get to it?
Or - if going to the work of taking it off, should I replace (118k on the clock)?
What is the current recommended replacement? (New/recon)
Your advice much appreciated.
Post #896114 6th Apr 2021 5:53am
Mdm
at that age and mileage treat it to a new or reconditioned one.
i've just used nps national power steering at leicester with good results, they advertise on ebay but being a bit old school if you ring you'll get better and dare i say it cheaper service. take on one off fit new back on the road same day or send yours away and they will overhaul it and send it back
Post #896300 6th Apr 2021 6:53pm
jimmyvonk
Yes, more I think about it the more I’m thinking a new replacement may be a better bet, give me another 100k plus miles before I need to worry again.
Post #896586 8th Apr 2021 5:39am
sako243
Are you sure it's the steering box?
Mine's got over double the mileage yours has and everytime I think it's got a bit of play it's something else - TREs, wheel bearings, etc. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #896651 8th Apr 2021 11:53am
