Home > Td5 > Intermittent battery warning light TD5 |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I think your brushes of the alternator are worn and/or sticky. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
5th Apr 2021 12:45pm |
Tufty Member Since: 27 Nov 2020 Location: Near Guildford Posts: 19 |
Thanks Roel, I now have a friend looking at it tomorrow so I will mention that!
5th Apr 2021 4:50pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
On the TD5 the vacuum pump for the brake servo is attached to the front of the alternator and it is a fairly common problem for the seals to fail allowing oil to leak from the vac pump into the alternator, forming a horrible gritty gungy mess which causes accelerated brush and slip ring wear. As the alternator starts to fail, you will initially get an intermittent warning light, then a complete loss of alternator output. It would be worth checking for this (look for oily yuk all over the alternator).
Sadly it doesn't seem possible to get the parts to overhaul a TD5 alternator in the UK (slip rings and brushes, etc) nor the seals for the vac pump, so total replacement is usually the only answer. |
5th Apr 2021 7:21pm |
Thank you Blackwolf, this is really helpful. I had hoped it might not be terminal as the problem is intermittent, but I feared it may be!
5th Apr 2021 9:52pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
https://www.unitexchange.com/
Have used this lot from S1 through to TDCI and they are old skool brilliant. Normally have a refurb starter or alternator on the shelf, but if not rebuild in less than a week. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
6th Apr 2021 7:15am |
Thanks familymad, I will look into this.
6th Apr 2021 8:57am |
