![]() | Home > Td5 > Door cards repair tips |
I've had some success in the past with that type of glue - Araldite or similar. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
If it in a thick enough area of the card, you can fit a short countersunk woodscrew with a head of an appropriate size to fit the nylon pin.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
It’s minimal in that area what is it made of it says pvc on the card but on cleaning the hole it’s very fibrous 🤔
Door Card Fir Tree Fastener Receiver (The Part That Breaks in the Door Card)Suitable for EZM500050 needs to be Bonded in
Product code: EZM500050REC BEARMACH are the stockers Last edited by dorsetsmith on 30th Mar 2021 3:33pm. Edited 1 time in total |
Thanks for that it doesn’t say what type of glue to bond it in with 🤔
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 ![]() ![]() ![]() |
Just did this repair a couple of months ago with Gorilla Glue two pack stuff. Failed the first time but the second time I left it clamped for ages and worked a treat. Still solid even after a test removal of door card. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Loctite/Hardman Double Bubble Epoxy works wonders and can be purchased in measured single use sachets that are pre measured
![]() e-bay search “double bubble epoxy” Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3480 ![]() ![]() ![]() |
I personally never had good success using epoxies (Areldite is an epoxy as well) on plastics.
I think polyurethane glues are better for this application. I use Wurth bond and seal a lot, and I bet that it is very strong in this application. I would still roughen a bit, especially the plastic thingy, and a good wipe with thinner (not white spirit). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
