![]() | Home > Td5 > Slimy balls |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5849 ![]() ![]() |
Thinking of rebuilding my swivels as they are leaking a little bit of grease, and I’m going to be in the area as I’ve got new discs, pads, and callipers to fit whilst I fit a new diff
Are these the correct bits for a late (06) 110with abs? And are these the quality balls that they used to be r has quality dropped since I last did some. https://www.paddockspares.com/da3180-swive...h-abs.html |
These ones come with Corteco seal and Timken bearings, so look better.
https://www.lrparts.net/catalog/product/vi...gory/1026/ |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
With Paddocks, add a “G” after the part number for the kit with OEM components....including Coteco and Timkin bearings. Search for .....DA3180G Patrick |
