Home > My Defender > Fuji 110 LS3 build |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2904 |
In for its first oil and filter change with Ged. Spanner check and all is looking good underneath
Click image to enlarge Click image to enlarge Just adding small changes now on the inside, managed to find a Heritage handbrake / LR leather gaitor and have ordered some bits from Croytec. Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
17th Mar 2021 9:15pm |
PWC1c Member Since: 10 Oct 2015 Location: Hertfordshire Posts: 194 |
Great build Andy where did you source the Heritage hand brake from also thinking of a set of gear levers
18th Mar 2021 3:43pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Looks great Andy!!
I've had the Heritage gear sticks and handbrake on my shopping list for ages, but never see for sale 2nd hand and I'm too tight to buy new James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Mar 2021 4:38pm |
Don’t forgot code Def25 for the discount with then? Or maybe Def5, can’t remember which I normally use. Andy
18th Mar 2021 5:58pm |
Andy, just realised you've not gone electric hand brake this time? James
18th Mar 2021 6:24pm |
I still have the JE handbrake kit in the box, just never got around to fitting it. When I sold the Last LS I machined a new console without the D4 handbrake switch for the new owner Andy
18th Mar 2021 8:36pm |
Focusing on the paddles at the minute as I only seem to driving in Tiptronic. Adjusting the paddles I have to mimic the switch on the gear stick is straight forward but fitting them on the boss has issues.
They get in the way and its a pain to power them thru the boss so I am going to mount them to the housing, slightly lower. I will basically split the unit into the Up and Down and then print a new housing for them. Easiest way to plan this was to get the new Laser scanner out and scan in the parts. I also bent the paddles in a little the help. Should have the housing ready for the weekend. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
24th Mar 2021 8:41pm |
Printed the new housing overnight. Cut the UP/Down paddles from the old PCS unit and into the new part. Then bolted to the lower cover and screwed up as normal. Really pleased with the position of the paddles. Just need to finish and paint it.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
26th Mar 2021 10:06am |
Wow! Nice work!! James
26th Mar 2021 10:20am |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
Uber cool!
Any further plans and developments ahead Andy, or are you just enjoying for now? Still got the 488 as a stablemate? Alex 110 Tdci Double Cab |
26th Mar 2021 10:29am |
Just do the easy things to it now and drive it but do plan a supercharger next. 488 prices where taking a tumble so I jumped ship thankfully not replaced it yet, enjoying the break and blood loss working on the defender Andy
26th Mar 2021 10:34am |
Can't wait for the supercharger build. Will it be fairly bolt on, or much modification needed? 110 Tdci Double Cab |
26th Mar 2021 11:55am |
In theory yes, but I am sure we will encounter some challenges Andy
26th Mar 2021 12:19pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10818 |
Nice work there Andy with the paddles 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
26th Mar 2021 8:17pm |
