![]() | Home > Puma (Tdci) > Strange intermittent rough idle and clunk - any ideas? |
KelvinB Member Since: 17 May 2018 Location: Crickhowell Posts: 24 ![]() ![]() ![]() |
Just had a similar thing. 200 mile journey on the motorway and when stopped at the destination had a really lumpy idle for a few seconds as if it was going to cut out but it then recovers.
Driving normally then engine is fine until you stop and then engine goes to idle again. Did you ever get a solution to this ? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Can you check for DTC’s via the OBD connector?
If the VCV was changed that recent it shouldn’t be that, possibly the clutch switch may be of interest but not guaranteed. The former flags no DTC’s but the latter, may well flag up DTC’s. A failing clutch switch can cause some weird issues, the clunk could be created by sudden changes in load and input to the engine. The clutch switch affects various different running characteristics and vital responses for the ECU that can cause all sorts of performance related problems. I’m not an expert, however, it’s possible that these things can be culprits. Cleaning the MAP and MAF sensors is worth doing too. Or if money isn’t an object ideally if many years old replaced all together. ![]() ⛽️🛢️⚙️🧰💪 |
Cheers Steve.
MAP and MAF will be cleaned in the morning and codes checked. There should be some as the EM light came on. I'll post an update when I know more |
Ah yes, if you’ve had the EML on the dash then that’s a sure sign there is a DTC or more present so you’ll be able to track the culprit down via that with any luck.
Turned out to be an oil contaminated MAF.
There's a breather tube that joins the air intake on the clean side of the filter. The breather tube joins the larger tube downstream and the airflow would normally dictate that the air coming from the filter and MAF would stop it getting contaminated but for some reason after a long journey it does. Maybe the engine oil is evaporating travelling down the breather and then condensing in the larger tube. Cleaned the breather and air intake, cleaned the MAF and it's now perfect. I've seen others with this problem and one solution seems to be a catch can on the breather. Maybe a different oil would also help. |
