Home > Technical > Timing chain replacement |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
May I ask if you also changed the sprockets?
Family member, his 2.4 is close to 150kmiles, and I have suggested to him to plan this service. When I check out the parts for him, I can find a variety of kits, some with sprockets, others with just chains and tensioners. Do you know what brand Turner supplies? I can find SKF locally... not sure on chain/sprocket quality, but I rate SKF bearings quite highly. https://www.vsm.skf.com/ie/en/products/VKML84006 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
25th Mar 2021 9:56am |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
I'm not changing the sprockets, after an investigation, they are in good condition with no obvious signs of wear.
I spent ages trawling through different kits from £110 for a complete chain kit plus sprockets and new timing cover to £675 for the same stuff. In the end I used Turner as they use all the components on their website in their engine builds, if it's good enough for them, it's good enough for me |
25th Mar 2021 5:27pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
Hi Badger,
How much did you spend in the end and do you have an idea of how much a mechanic will charge for it? + or - obviously. Mine has done nearly 100000miles and I want to try and get that done next year. Thank you Fábio |
25th Mar 2021 5:31pm |
Judging from Badger's first photo, the chain is one pin diameter x2 longer than the original.
I do not know what diameter that pin is, but if it was 3mm, that would be a wear of 45microns/roller. So probably difficult to see any wear, if any, on the sprockets. If there is wear, i think it will be more pronounced on the intake cam sprocket, as there are far less teeth in mesh with the chain. Or maybe this is a wrong assumption. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
25th Mar 2021 7:18pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 528 |
^^. "that would be a wear of 45microns/roller. So probably difficult to see any wear, if any, on the sprockets."
... Could this be below production tolerances ? |
26th Mar 2021 8:26pm |
Haahaa
I hope the punch and die that makes the links is a lot more accurate than that. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
26th Mar 2021 8:49pm |
Has anyone been able to determine chain stretch based on crankshaft and cam shaft position sensor readouts? Probably would need a baseline, but possible to calculate back the stretch on the length of chain between the crankshaft sprocket and the camshaft sprocket? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
3rd Jun 2021 5:36pm |
