Home > Puma (Tdci) > MOT & Exhaust condition query |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2638 |
Can you go old school and buy an exhaust repair thingy from Halfords along with a tin of Dum Dum.
When i was started driving we would use an old Coke tin, exhaust paste and jubilee clips. Then worried about swapping the section over, normally as a summer job. |
23rd Mar 2021 7:53pm |
cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117 |
https://www.gov.uk/guidance/mot-inspection...8-nuisance
Look at 8.1 As long as it is still secure and not deemed excessively noisy, it shouldn't fail. If you're replacing it though, why not use repair paste or a bandage just to get through the MOT with no doubts. |
23rd Mar 2021 7:59pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1600 |
blowing exhaust is a fail.
stainless bit of waste of brass and the sound can be a bit tinny for many folk |
23rd Mar 2021 8:09pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 353 |
Heres the offending seam
Click image to enlarge I'll have a look for the paste. Keith |
23rd Mar 2021 8:16pm |
tube of exhaust paste from local kwik fit type place or screwfix etc will work as a temp repair.
as long as it aint blowing you should be fine. even if you left the replacement exhaust in the car if it arrives and you cant get it fitted at least the tester knows your gonna fix it |
23rd Mar 2021 8:19pm |
Not according to the MOT testers' manual it isn't. Only a serious leak that affects either emissions or noise. I've already posted 1 link , here is another: https://www.gov.uk/guidance/mot-inspection...tion-6-1-2 |
23rd Mar 2021 8:51pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 484 |
Holts gun gum will make it |
24th Mar 2021 6:31pm |
