Home > Faults & Fixes (L663) > Cruise Control problems ?
lootawi
United Arab Emirates
Hello everyone,
wanted to share this and check if someone has faced the same issue !
I just received my L663 110 X 2 weeks ago and the cruise control have failed to work at least 4 times until date ! and my car has only done 2000 km, it comes with ADAPTIVE CRUISE CONTROL as well.
wonder if anyone have faced the same issue or not yet !?
Thank you in advance.
Post #892931 21st Mar 2021 2:10am
SN
What do you mean by failed to work? Could you not turn it on? Set, reset? Or did it just stop working (ie dropped out when active) Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #893025 21st Mar 2021 3:42pm
Gareth
Not had any issues with it at all. Great system. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #893039 21st Mar 2021 4:52pm
defender_uk
you need to check that Cc is activated and not the speed limiter. Caught me out when I first picked it up. Works on the same button the steering wheel and you have to toggle between the two. 2020 First Ed 110.
replaced by 2021 250 110 Commercial
Defender_uk
Post #893104 21st Mar 2021 8:47pm
lootawi
nope it just doesn't function ! i toggle between the CC and the LIM the limiter do work properly every time unlike the CC, just fails to function i cancel and try to switch on (engage) but still doesn't !! strange it even gets worse by time.
a ratio of 90% of the times i tried engaging it, it fails to work ! i have to stop the car turn it off and start again to engage it.
somehow strange !
Post #893125 22nd Mar 2021 4:00am
lootawi
does not work ! trying set, reset +/- nothing does work ! and once i engage the LIMITER works fine but when i turn back to the cruise control it doesn't unless i switch off the car and start it again !.
Post #893126 22nd Mar 2021 4:03am
lootawi
i toggle between both LIM does work fine ! but not the CC !
Post #893127 22nd Mar 2021 4:04am
