Home > Technical > Large key door locks? |
taktak Member Since: 05 Jan 2021 Location: Chester Posts: 10 |
Have you explored an add-on for your existing key? e.g..
https://www.yourcare.org.uk/category_schem...A-EALw_wcB |
20th Mar 2021 9:10pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Maybe worth a visit to a key cutter to see if they have a suitable blank with a larger end, more like the ignition key Just because you're offended doesn't mean you're right.
20th Mar 2021 9:14pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 536 |
Cheers, one to look into.
20th Mar 2021 9:17pm |
You could change the handles to the later type which, in turn, use larger locks so that they share a key with the ignition. To get the most benefit you'd also need to change the ignition lock so you only needed one key for the whole vehicle (except fuel cap) but that's not essential. Darren
20th Mar 2021 9:42pm |
More investigation today, stripped out the door lock mechanism all works fine, key in locks and works well until you connect up the inner button and it all goes stiff again.
So answer is order new interior locks. https://www.ebay.co.uk/itm/Land-Rover-Defe...0338109361 Happy wife again..... |
21st Mar 2021 7:35pm |
