Home > Maintenance & Modifications > Wolf door tops |
northernerindevon Member Since: 27 Feb 2018 Location: Bristol Posts: 62 |
I can't advise whether the series channel will fit but I have the ex-military doortops on my 90 & suffered the same rattle - I'll testify it'll drive you mad.
In the end I bit the bullet and got the Garrison kit. https://www.mudstuff.co.uk/products/garris...&_ss=r Has everything you need and has solved the issue. Silence is golden (at least silent doortops!) Cheers, Paul |
19th Mar 2021 8:04am |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 151 |
Like Paul, I went down the Garrison route from Mudstuff. Then days later this popped up in the for sale section
https://www.defender2.net/forum/topic74957.html?highlight=door Might be worth an enquiry Cheers Laurie 90 rebuild thread - https://www.defender2.net/forum/topic62909.html |
19th Mar 2021 9:02am |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 625 |
I have used Woolies channel in Wolf door tops with excellent results, no rattles, glass fit snug to the channel and slides with enough resistance to hold the window from sliding back and forth.
19th Mar 2021 8:41pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Rather than shell out on the Garrison kit, speak with Shroppy on here.
He sourced a very similar product from somewhere and was selling some kits made up to do the windows. |
20th Mar 2021 4:32am |
