![]() | Home > Td5 > Clutch pushrod |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
There are 2 pushrods, one is 99mm long (FTC5199) and the other is 105mm long (FTC3192). Rgds.
Chris |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
Thanks - I Will try FTC3192๐๐ป I bought FTC5199 as it was said to fit all Defender Td5 ๐ค
Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6162 ![]() ![]() ![]() |
I had exactly the same issue when I built my 110 back in 2010....
bought a slave cyl, thinking "ah, Td5 and 300Tdi are the same".... not.... I had a slipping clutch issue from day 1... just looking at the clutch pedal would cause a slip... Think the slave cylinder also had a deeper "hole" in the end of the piston as well, but as said above, the Td5 is different (shorter) so it gives a little more slack in the system... or just not pressuring the friction plate all the time. |
Weird.... I have the opposite problem... i have pressure on the pedal but it feels Like the clutch is not pressed all the Way - I am having a hard time changing gears๐ค 88 Ser. 3 1980 -sold
I just changed the master cyl.... I got a brand new car ๐.. After close inspection there was a tiny bit of brake fluid on the pedal. I was certain it was the pushrod or something else as the movement in the clutch pedal felt normal...guess it did not produce enough pressure to function properly.
