Home > Series Land Rovers > Does plasma rope rot?
Gareth
My Series 2a has a Mayflower PTO winch, which I converted to have plasma rope instead of the original steel wire. I did this by replacing the roller fairlead with a smooth aluminium guide slot. It’s been fitted since 2006, and the rope is of the same age.
It’s been out there in the elements all the time and I’ve not really paid much attention to it. I last used it a couple of years ago to winch my other 2a up a hill into the garage.
Today I was greasing and oiling everything and decided to unspool the rope and check it out. It looked ok, but very dirty and full of algae.
Does plasma rot? Or is it still good for service? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #892183 17th Mar 2021 7:59pm
jst
speaking with respect to Dyneema it doesnt degrade with light but looks bad. it degrades with abrasion from mud/silt/rocks etc. either through the fairlead or over the ground. hence why most run Ali fairleads to reduce wear. Sounds like it just needs a good clean with warm water - no soap! then dry it before refitting. its doesnt rot. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #892190 17th Mar 2021 8:24pm
Gareth
👍 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #892194 17th Mar 2021 8:37pm
Alternatively take the rope off the winch, chain shorten it, and run it on a cool cycle through the washing machine while the domestic authorities are not around. Works a treat. I used to clean all my caving ropes that way.
Post #892223 17th Mar 2021 10:39pm
Gareth
I did think of that, but having just forked out for a new washing machine, which she is very proud of, I fear that would be a step too far! 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #892231 17th Mar 2021 11:50pm
Ideal, it is still under warranty! Rolling with laughter
Post #892233 18th Mar 2021 12:41am
jst
put it in a bag if you do machine wash it and run the machine through first empty to clear out detergent Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #892286 18th Mar 2021 9:39am
That's what pillowcases are for. Laughing
Post #892289 18th Mar 2021 9:45am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I thought I had seen somewhere that direct sunlight can degrade it over time, perhaps on the goodwinch website or somewhere else that sells them 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #892319 18th Mar 2021 12:13pm
markb110
I bought and use a cheaply neoprene winch cover from eBay.
Fits well enough for me and keeps the weather off it. Warn 9.5 XP.
Rope that you sometimes see wrapped around bumpers will degrade with sunlight and should never be used for a recovery. I was taught a long while ago now to trust your own equipment, not someone else’s.
Post #892329 18th Mar 2021 1:08pm
jst
It degrades the appearance not the strength. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #892337 18th Mar 2021 1:38pm
