Home > In Car Electronics > Towing electric box clicking |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6632 |
Non LR towing electrics presumably, and this is a voltage sensing relay for the ignition feed.
Genuine LR electrics for Pumas don't have a voltage sensing relay. Was the vehicle hooked up/on charge when it was doing it? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
16th Mar 2021 8:56pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
I don't know if it's original, but as you say, if it's a voltage sensitive relay then perhaps it isn't.
The feed for it must be from the main battery, everything else inside that I've added is powered by the leisure batteries which are completely independent, however they are connected to the main battery via a Victron Cyclix relay...but that is only a one way system, ie when the voltage is high enough to open the circuit. There is no EHU for the main battery or the 3 leisure batteries...everything works without the need for EHU. At least I know what is causing the noise...the only real difference to me not hearing it before is I've come back from a drive 15 minutes before I noticed the noise. So something must be causing the VSR to open and close. |
16th Mar 2021 9:24pm |
