![]() | Home > Maintenance & Modifications > Footwells and Anti Rust treatment - advice on process sought |
Just in the process of doing this on my 03.
I've cleaned back, prepped a few bits for welding etc. My process is using the following: 1 Treat cleaned metal / rust with Bilt Hamber Hydrate 80 2 Paint with Bilt Hamber electrox 3 cover seam with Bilt Hamber Dynax Seam 4 Top Coat with Buzzweld CIO 5 Colour with Buzzweld LR Coach Enamel Heres the current stage of the process Before ![]() Click image to enlarge Cleaned ![]() Click image to enlarge Hydrate 80 applied ![]() Click image to enlarge |
rustyredwreck Member Since: 16 Jan 2020 Location: Oxfordshire Posts: 24 ![]() ![]() ![]() |
Thanks for taking the trouble to post the pics - just started the job today hence the late delay in saying thanks.
Your answer was very helpful. Thanks kind regards Neil |
Lesson I learnt is take the time to wire wheel it all back.
I've finally got around to starting to paint mine. I'm doing a test of Bilt Hambler on the drivers side and Buzzweld stuff on the passenger side. |
