Home > Puma (Tdci) > Britpart one price halfshafts
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
https://www.lrdirect.com/LR072977-supplied...TPART.html
Fitted a set of these to my 90 today as the flanges were f***ed!
They appear to be really well made and other than a couple of stubborn bolts, were easy to fit.
I refitted with a set of the proper bolts that have the locktite stuff preinstalled - which apparently was a mistake (hopefully I never have to change them again!).
This was the first job that has ever gone smoothly working on the truck, so really chuffed!! 2011 CSW XS 90
Post #891135 13th Mar 2021 5:28pm
I fitted a set to my 110 a while back.... so far, all OK... Thumbs Up
Post #891144 13th Mar 2021 5:52pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
The first job I did on my 110 when I got it a couple of years back was to fit a pair of these.
I was pleasantly surprised how quick & easy it was - I was expecting things to go wrong.
So far no issues with these. (Plenty of other issues in other areas of course! Smile )
Post #891167 13th Mar 2021 7:13pm
williamthedog
I fitted a pair to mine a while back, all good Thumbs Up
Post #891216 13th Mar 2021 9:08pm
bear100
Why would you change these? Are they different to the genuine Land Rover? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #891222 13th Mar 2021 9:30pm
williamthedog
They used 2 piece shafts, ie, drive flanges. Another point to wear and become noisy.
Post #891233 13th Mar 2021 9:48pm
bear100
Ahh yes i got you now Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #891242 13th Mar 2021 10:18pm
The genuine LR one-piece halfshafts are terrifyingly expensive, something like £600. The Britpart ones cost a fraction of that, and, unusually for Britpart parts, forum feedback seems generally ok.
Post #891245 13th Mar 2021 10:33pm
SJM2018
The only obvious difference I noticed (other than being one piece!) was that the Britpart ones were slightly heavier and the shaft had a consistent diameter (the genuine two piece set I remove appear to have a taper between where the bearing sit and where it engages with the diff. 2011 CSW XS 90
Post #891260 14th Mar 2021 6:53am
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Another vote for the Britpart shafts, not had any issues.
Same for shocks, springs etc. I've used over the years. Just don't trust their filters personally but then I had two bearmach filters fail on me and one faulty from manufacture so it's not just Britpart that have the odd dodgy part. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #891411 14th Mar 2021 7:00pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Fitted these a few weeks back and all good. One minor complaint is that they seem to rust very quickly so will need removing and the flanges painting properly, mine have gone orange in a matter of weeks. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #891607 15th Mar 2021 4:12pm
Mdm
fitted 2 sets of these now and they seem to last .paint is really paint on them and they rust within a week of fitting so need cleaning and painting properly when fitted
no issues and no clunks
Post #891617 15th Mar 2021 5:13pm
williamthedog
Mine weren't painted, so I had to do mine before fitting, no great hardship in that though.
Post #891660 15th Mar 2021 8:31pm
HardCharger
When switching out to the one piece shafts, are there any other parts required during the procedure? (seals, new bolts, gaskets, etc.?)
This is already on my to-do list and I want to make sure I have all the necessary items before I attempt the work. Won't do to have it all apart only to find out that there are missing parts.
Post #891723 16th Mar 2021 4:33am
Griff90bowler
Wales
Owlet fitted these to mine on its last service so can’t be bad 👍
Post #891731 16th Mar 2021 7:40am
