Home > Maintenance & Modifications > VCV questions if you please
bear100
Hey all just a few questions
Ive convinced myself that the VCV is faulty so i going to bite the bullet and change it!
Is the Ford part the same?
How easy is it to change and can it be done in situ?
And lastly, I've read that the VCV should be relearned but not essential, is this the case?
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #889645 7th Mar 2021 1:57pm
There are lots of threads on this. In short though, yes it's the same as the Ford part and the number is on here somewhere, they're tricky to change but not impossible and no, it's not necessary to do a relearn.
Here's a good place to start: https://www.defender2.net/forum/topic63786...p;start=15 Darren
Post #889649 7th Mar 2021 2:20pm
williamthedog
It's about a 30 - 45 minute job and as said you dont have to do a relearn. Thumbs Up
Post #889688 7th Mar 2021 5:35pm
bear100
Thanks for the tips Thumbs Up
New VCV arriving this week! 2016 Range Rover Autobiography 4.4 TDV8
Post #889842 8th Mar 2021 12:55pm
spudfan
Ireland
https://www.lrdirect.com/LR009837-Valve-Fu..._https=yes 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #889925 8th Mar 2021 5:27pm
I got mine from PFJones, really good well worth doing I found.
There is a tightening torque for the fixings applicable in the WSM, but not absolutely essential just don’t over tighten.
I managed to do mine with everything else left in situ, the biggest thing to be careful of is that you don’t drop the fixings by accident as it’s very easily done.
Other than that no problem at all. No Guts, No Glory.
Post #889985 8th Mar 2021 7:36pm
bear100
Looks a bit tricky but I’m sure i can sort it Bow down
Post #890013 8th Mar 2021 9:09pm
bear100
Well I fitted it today........horrible job! I have big hands and struggled the whole way through!
Great tips on tools to use, I found using the flexible 1/4” tool great for the slack and a combination of what ever to tighten it all up.
Now let’s hope it relearns itself! 2016 Range Rover Autobiography 4.4 TDV8
Post #893095 21st Mar 2021 7:26pm
