Home > Maintenance & Modifications > BSA remap
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
BSA remap
Im thinking of having this done on my 09 90 after engine rebuild, but excuse the cynicism i cant believe they make that much difference, i read all the threads on here can some ome explain exactly what it does to your Landy please to make such a difference, im nearly there just need that little push to get me over the line
Many thanks
Pete
Post #889646 7th Mar 2021 1:58pm
bear100
Hello
I had the BAS remap done a good few years ago now and i can honestly say does transform the engine immensely! so much more lively, didn't realise how flat the standard map was.
it adds software to stop the EGR valve too, i have a plug in device with my remap which lets me choose between standard, towing and full. i always keep mine in the towing setup which works best for me.
Honestly, driving it for the first time after the remap i was so impressed and instantly knew my money was well spent.
i had done a lot of research on remaps and different vendors but settled with Peter at BAS because he had carried out a tremendous amount of work setting the parameters for a safe map.
may be some one who lives near you who has had one you and could have a test drive?
You won't regret having it done Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #889648 7th Mar 2021 2:08pm
corgi1
Thanks Bear, im at the stage now of getting it, did you find it hard to do yourself?
Pete
Post #889652 7th Mar 2021 2:28pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
As above plus Pete's after sales service is second to none.
I've had a BAS remap for 100k miles of very mixed motoring, autobahns to green lanes, Alpine mountain passes to motorways and the key thing is that it makes the Defender more "drivable" in all conditions.
Have the EGR disabled and the speed limiter removed for the best effect.
Talk directly to Pete to see if an uprated intercooler is required for your normal useage, he will tell you honestly either way. Just because you're offended doesn't mean you're right.
Post #889653 7th Mar 2021 2:29pm
corgi1
Brilliant thanks very much, was it hard to do yourself? im crap with computers !!!
Post #889656 7th Mar 2021 2:37pm
corgi1
one more question do you use more diesel or is it the same?
Post #889657 7th Mar 2021 2:41pm
Co1
I got slightly better economy with a 170 map from Pete.
Post #889658 7th Mar 2021 2:44pm
corgi1
Thumbs Up
Thanks
Post #889660 7th Mar 2021 2:48pm
shropshiredefender
Yes me to - too old to read instructions and very impatient Whistle
It was not difficult and where I "misunderstood" the instructions a quick message exchange on the BAS website soon had me sorted out. Pete appears to see what you're doing over the ether - magic and witchcraft Twisted Evil
Fuel consumption on my 2011 110 2.4 USW was 26 ish mpg before and after tuning. Just because you're offended doesn't mean you're right.
Post #889662 7th Mar 2021 2:59pm
corgi1
Brilliant will get it sorted many thanks Gents
Post #889664 7th Mar 2021 3:05pm
bear100
No its very easy, basically plug the unit into the OBD under the steering wheel then turn ignition on, the unit wakes up and you choose one of the 3 maps then let it load up for a few minutes and your ready to go, also has a fault reading function on there too! so really really easy.
Have a chat with him you may even get a discount Whistle 2023 Defender L663 V8
Post #889670 7th Mar 2021 4:05pm
Deandef123
2007 Defender 110 Puma 2.4 XS CSW Blenheim Silver
Hi all. 1st time posting. I have a 2.4 tdci and I’m looking to get a BAS Remap. I live in Warrington, Cheshire. Where is the best place for me to get this done, relatively locally?
Thanks in advance.
Dean
Post #960985 8th Aug 2022 7:16am
shropshiredefender
Click this link and do it on your drive.
https://bellautoservices.co.uk/store/bas2-rrc-defender-2-4l-tdci/
I've used this remap for over 100k miles together with speed limiter removal option, can't recommend it highly enough.
Bell Auto Services back up second to none. Just because you're offended doesn't mean you're right.
Post #961003 8th Aug 2022 12:45pm
