Home > Faults & Fixes (L663) > Light tapping noise/sand from top of windscreen/roof area
Patriot0290
United States
First, my July 2020 build P400 HSE is outside the affected VIN # of the A pillar trim fix.
At speeds of 75mph or higher, I have a constant, tapping, sifting sand type noise coming from the sunglasses holder area, where the roof meets the front windscreen. I do have the Explorer pack with the Expedition rack, and wondering whether its the rack.
 2020 Defender 110 P400 HSE (Tasman Blue/Khaki)
Previously:
1995 Discovery
1995 Range Rover County Classic
1998 Range Rover
2000 Discovery II
2004 Range Rover
2007 LR3
1995 Range Rover County LWB
Post #889624 7th Mar 2021 1:35pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Could be or it might be a loose roof rail. There is a small section on both sides toward the front of the roof, someone in the Facebook group removed that section to fit a light bar but in doing so snapped the bracket and to get a replacement LR have told him he would need to order the whole roof rails again as they don’t supply then separately. Check if they are secure on yours from when the dealership fitted your expedition rack. I know they are not very good quality and snap easily. Someone I know is going to try 3D print nylon ones which would be a lot stronger.
Post #889630 7th Mar 2021 1:57pm
Simon Audi
Re: Light tapping noise/sand from top of windscreen/roof are
Hi
Did you ever get to the bottom of this noise?
I have the D300... and for last 3 weeks its developed a new noise when you get above around 85MPH
Its Like a fluttering noise at the top of the windscreen / roof.
I do not have a roof rack or roof rails.
All trims seem in place and connected OK.
Maybe its the A Pillar noise? - but its only at high speed and the sound is the top of the screen / roof - not at the side.
THANKS
Post #909684 27th Jun 2021 7:34pm
Patriot0290
United States
Yes I fixed it myself, detailed in this thread:
https://landroverforums.com/forum/2020-def...lf-106769/ 2020 Defender 110 P400 HSE (Tasman Blue/Khaki)
Previously:
1995 Discovery
1998 Range Rover
2000 Discovery II
2004 Range Rover
2007 LR3
Post #909720 27th Jun 2021 10:40pm
Simon Audi
Thanks
Did the noise sound like it was from the A Pillar - or Top of the Screen?
Post #909726 28th Jun 2021 5:08am
Patriot0290
United States
From the driver’s seat, it sounds like it’s coming from the top of the windshield, near the rear view mirror assembly. But from the passenger’s seat, it’s clearly coming from the A-pillar. 2020 Defender 110 P400 HSE (Tasman Blue/Khaki)
Previously:
1995 Discovery
1998 Range Rover
2000 Discovery II
2004 Range Rover
2007 LR3
Post #909766 28th Jun 2021 11:26am
Simon Audi
THANKS
Post #909784 28th Jun 2021 1:01pm
