![]() | Home > Technical > Nanocom Evolution Software Update |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Just updated my pre BBS nanocom evolution with the new BBS software upgrade.
![]() Click image to enlarge The software is available in the restricted section on the nanocom website. Also download the Before and Later how to guides as well. The whole process took about 10mins to do and the procedure was well documented showing each step clearly. You will need an external 12v power supply and a usb lead to connect the evo to the computer. The first stage, Step 1 of the upgrade involves replacing a file in the NC_firmware drive which is corrupted. This is just a drag and replace exercise which takes seconds to do. Next comes Step 2 of the upgrade itself which involves powering the nanocom and then connecting the usb lead. You need to go through the menus to get to Kernel upgrade but again it is all well explained in the how to guide. When the unit is powered up go into the nanocom menu ![]() Click image to enlarge Then select Setup ![]() Click image to enlarge Scroll across until you see Kernel Upgrade ![]() Click image to enlarge Then click on Kernel Upgrade and you will get this screen. I unplugged the usb from the computer then reconnected it and waited for the bong from the desktop to tell me it has found the usb device before I clicked on Run Kernel Upgrade so I knew that the nanocom and computer were in sync. ![]() Click image to enlarge The nanocom goes blank and then you just run the NanocomEvoKernelManager.exe from the downloaded upgrade and it does everything else. Once finished you unplug the nanocom and away you go, simples ![]() ![]() Click image to enlarge The instructions for this procedure are spot on in explaining the process which did instil confidence on my part when doing this and hope this how to will aid your upgrade experience ![]() Brian. EDIT: Meant to say that if you check the "Overwrite Target Config" option this will clear all user config files and you will also need to re-enter the unlock codes before you can use the nano on your vehicle. |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
Once the original Nanocom Evolution has been upgraded to the BBS software future upgrades are even simpler. You no longer need the 12v power supply as all you need to do is remove the sd card and plug in the usb. This screen appears and you then click on kernel and the screen will go blank as in the above how to, then just run the upgrade software file from the computer. Remember to remove the sd card otherwise the computer just reads the card and treats the nanocom as an external drive meaning you wont get the below screen when plugging in the usb lead.
![]() Click image to enlarge Brian. |
Gunner Member Since: 31 Dec 2010 Location: Oxfordshire Posts: 6 ![]() |
I'm having some problems updating my Nanocom Evolution (pre BBS)
I've done step one by replacing the file in the NC_firmware drive however at step two I can't get the Nanocom to show as a drive in my laptop when powered by a 12v supply and connected by a USB lead. The frustating thing is that it will appear as a drive when connected to the laptop by a USB lead only but then the the 'Set Up'and 'Kernal Upgrade' screens cannot be accessed. Any help or advice would be appreciated. |
When the usb is plugged in without 12v power the computer will recognize the nanocom as an external drive but the usb is not capable of powering up the nanocom to allow access to the kernel upgrade option. On the desktop unzip the upgrade files and have them minimized on the desktop to allow easy access later. The process I used is this:
1. Remove the SD Card from the nanocom. 2. Connect up the nanocom via usb only and rewrite the NC_Firmware file. 3. Remove usb from computer and power up the nanocom with the 12v dc power supply. 4. Go through the nanocom menu until you get to the kernel Upgrade screen. 5. Reconnect the usb to the computer until you hear the bong that it is in sync. 6. Press the Run Kernel Upgrade button. The nanocom screen will go blank, this indicates that the nanocom has entered the upgrade mode. 7. Open the previously minimized upgrade folder and double click on NanocomEvoKernelManager.exe 8. the update screen will appear and give you the option of overwriting the original user config files. Click on Run Upgrade and the program does the rest. I would post some photos but I'm away in the caravan fishing for a few weeks and the vodafone dongle I'm using is not in a 3G area so it is very slow to use. HTH Brian. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
Should the NNcom be recognized right away by the PC?
thanks MK Puma 110" SW ............................................................. Earth first. Other planets later |
Yes it will be recognized as long as the sd card is removed and only the usb lead is used to connect it to the computer. Check My Computer when you plug the nanocom in and you will see the new drive appear.
The problem I have is that there isn't a 'bong' when my Nanocom is connected by 12v supply and USB to my computer.
Is it still safe to continue and run the Kernal Manager.exe file ? The SD card has been removed and the new NCSET.app has been copied to the Nanocom and overwritten the old file to correct the bug which affects Kernel Upgrading. And the compter speaker volume is up and hasn't been muted. |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Sometimes ive had it where i do not get a "bong" ive still updates it no problems. ive3 done about 20 sofar with no problems so you would be unlucky to have issues.
Pete |
My PC does not like the box neither. All S. Packs on. Tried on several PC`s. Must be one of the faulty ones. The seller (sponsor) said no updates coming in the future........ ![]() ............................................................. Earth first. Other planets later |
Try plugging the nanocom in with the 12v and the usb. Scroll through to Kernel update and press it. When the screen goes blank run the kernel upgrade software on the computer and check to see if the device is present on the upgrade screen. If you look at the 6th picture on the second post and look just above the Run Upgrade tab you will see Verify......... When the program starts up IIRC it will state Device found or something like that. Run the kernel update and see if it works. I am away just now and don't have access to the software update as it is on the desktop computer.
Also what version of windows are you using? Have you full Administrator rights? Is there anti virus software running in the background, especially a resident shield app? Brian. |
DanoDEF Member Since: 12 Oct 2011 Location: East Slovakia Posts: 2 ![]() |
my nanocom died during an upgrade kernel. I basically this caused by disconnecting the USB. What now?
