Home > Maintenance & Modifications > Front Door Sill Protectors
ChrisDefender
Hi all,
In the process of tidying up the side sills as they were looking a tad scruffy.
To finish it al off I have just ordered a set of the stainless sill protectors for the front doors. However, I have just read that if I have the uprated 2011> bottom door deals, if these protectors are not stepped (ie like the ones from 4x4 Overland) then it will foul or break the fastner clips on the new seals.
Can anyone confirm this is the case, or will I 'get away with it'!! Hope so! Neutral
Cheers all.
Post #844837 20th Jul 2020 10:14am
Argee
Well I fitted front ones with those door seals under the carpet and it was fine.
The back door ones on the other hand.... Rolling Eyes
Post #844850 20th Jul 2020 12:05pm
ChrisDefender
Cheers mate,
It's just the front ones I am doing so I hope it will be OK. They are ordered now so I will see how they fit and if need be I will have to bite the bullet and get the stepped ones - but ever the optimist!!
Thank you for the reply Thumbs Up
Post #844851 20th Jul 2020 12:12pm
Argee
Hope it goes ok, stick some pics up when its done. Thumbs Up
Post #844862 20th Jul 2020 1:42pm
ChrisDefender
Cheers, will do. It will be a week or so as I am refurbing the sills etc as well. Good or bad I will post some pics!!! Rolling with laughter
Post #844866 20th Jul 2020 1:58pm
stephan123
I bought the front and rear door sill protectors from 4x4 Overland. No issues with the fronts fouling the door seal. Rear door seal has been letting in small amounts of water but nothing major. Overall quality product and a worthy upgrade.
Post #844884 20th Jul 2020 3:40pm
ChrisDefender
Hi Stephan,
Exactly, the ones I have ordered before I read the info on the sills fouling the rubber seal fixings are the standard, right angle non-stepped ones, so I hope they will still be OK.
If not I will have to order the stepped ones like yours.
Cheers all Thumbs Up
Post #844888 20th Jul 2020 3:55pm
ChrisDefender
Hi,
Realised I hadn't posted these in this post as promised. Used the non-stepped ones in the end. Very happy with the results, no fouling of the bottom door seal clips and the doors still shut well, so all in all very happy Thumbs Up Certainly has smartened it all up.
Post #850468 17th Aug 2020 10:53am
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Can I ask if you have any soundproofing under the mats on the front seat boxes? I’ve fitted a similar right angle kit and having bother getting doors to shut properly.
Post #888723 2nd Mar 2021 9:26pm
ChrisDefender
Hi mate,
No, I dont have any soundproofing on the outer of the seatbox, just the heavy duty matting from Wright Offroad, which is approx. 10mmm thick and does the job well. I put my silentcoat on the inside of the seat boxes to stop the vibration a little.
I did make sure the sills were up as tight as they could be to the seat box etc.
At the same time as installing the treadplates, I also put on new genuine door seals and the upgraded bottom door seals. The doors shut fine to be honest, you do have to give them a 'confident' pull otherwise it takes a couple of goes, but certainly wouldn't say I have to slam them or anything.
Hope this helps,
Cheers.
Post #888775 3rd Mar 2021 10:05am
MussEd
Hi Chris, yep very helpful. Think you’ve confirmed I’ll need to get the seats out, remove the soundproofing and stick some inside the boxes instead. Thanks for the reply!
Post #888779 3rd Mar 2021 10:38am
ChrisDefender
Hi, yep I guess it depends how thick the soundproofing is, but with the Wright Offroad system being so thick there is just no room for any extra on the outside. I would recommend this over the standard Hardura stuff or carpet without hesitation. it means you don't need the metal edge corner protectors either.
I just put silentcoat on the inner walls of the seat boxes, then some on the underside of the sliding access trays and this has made a big diference.
With LR tolerences, I think they will all be a bit different! Whistle
Good luck.
Post #888780 3rd Mar 2021 10:47am
