Home > Td5 > Diff upgrades
Page 2 of 2 <12
excossack
For me it would be general road use - to/from work. Towing cars around race circuits and forest tracks. Things get heavy with a Harvey Frost(Changed a bit since these pics - https://www.defender2.net/forum/topic36874...rvey+frost ) on tow and a MK2 Escort or an Evo hanging off a rope coupled with muddy/wet/churned up forest tracks wheels do slip.
Standard BFG At 235/85 R16 tyres.
I think time to send a few emails(already contacted Nigel) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #888467 1st Mar 2021 4:01pm
For that application I would say that a standard Puma set-up with a four-gear front Rover-pattern diff and a four-gear P38 diff at the rear would be entirely adequate. The same set-up but with torque-biasing diffs (e.g., Ashcroft ATB) would be better still, but mainly from the towing-on-loose-surfaces aspects, although it is stronger too. What you describe is not especially heavy-duty use of the vehicle.
An Ashcroft ATB in the transfer box might also be worth considering.
The two-gear front diff is not really strong enough for any purpose, in my opinion.
Post #888527 1st Mar 2021 8:05pm
jst
whens shes loaded like that is it not the front that usually slips/spins first? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #888531 1st Mar 2021 8:11pm
excossack
Thanks BW. I do have a centre ATB and that works OK.
Its not heavy use, but at times, grip is not always there especially, up hill drags in muddy forest roads. 1999 Defender TD5 110
Regards
John M0VAZ
Post #888535 1st Mar 2021 8:25pm
excossack
The front does spin and now and then the rear. 1999 Defender TD5 110
Regards
John M0VAZ
Post #888536 1st Mar 2021 8:26pm
Inguz
I have an ARB sitting here beside me and it's a solid piece of kit. Many people run them in their Salisbury/Dana 60 without any issues, and some of them do heavy work. I'll be installing this in the coming days, but unfortunately won't get to test it for a while as it's a full vehicle rebuild being done.
Post #888847 3rd Mar 2021 5:57pm
jst
for your application and based on front spinning firstwhich is how i read your reply i would be putting a locker in the front axle. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #888863 3rd Mar 2021 7:26pm
diduan
Bulgaria
I agree some kind of traction aid is a huge improvement over open differentials + it adds strength. We went skiing with the kids today and I almost got stuck, because right side of the vehicle was in the deep snow, left side had traction (theoretically) but it was no help. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #888872 3rd Mar 2021 7:57pm
crashmtb
Canada 2002 Defender 110 Td5 HT Coniston Green
drakes wrote:
I have been runing a Quaife Torque Sensing dif for the last 30 years and over 300k ( moving it from one vehicle to the next) and it still performs faultlessly and has required no maintenance except for normal oil changes
This is what I’m planning. I have a very early MY2002 110 with a Salisbury, otherwise I’d put an Ashcroft ATB.
Won’t have problems building it here in Canada - if I tell my axle guy I have a Land Rover Salisbury axle he says he’s never worked on one. Tell him it’s a Dana 60, but metric, and it’s the 5th this week 🤣
Post #890030 8th Mar 2021 9:51pm
excossack
Cheers JST. An ATB would be my choice. Would having an open diff at the rear and ATB up front cause any cornering issues in the dry/wet on tarmac? 1999 Defender TD5 110
Regards
John M0VAZ
Post #890088 9th Mar 2021 8:31am
No, it won't. I have run many miles with ATB front, open rear, after breaking rear diffs.
Post #890113 9th Mar 2021 9:48am
excossack
Cheers BW. 1999 Defender TD5 110
Regards
John M0VAZ
Post #890144 9th Mar 2021 11:16am
Page 2 of 2 <12
