![]() | Home > Modifications & Maintenance (L663) > Retro Fit Adaptive Cruise Control Defender 2020, POSSIBLE?? |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Powerful uk found the ccf files for TR2 today so it won’t be long until they crack that next
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
I saw in the YouTube videos that the V8 has the steering wheel shift paddles, so these can probably also be added to the base L663? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
That was something Powerful was already looking at
That's not what I've see or read?
JLR corporate ~ Mr Skywalker (?) has been back in touch and wheels are turning. It seems the issue is very much dealer based and it's been stated that his dash cam recorded "something" at the dealers that has caused him concern. It's self evident that he's both more technically competent and invested in fixing his vehicle than any of the staff at his local dealer's. The dealer looked at this and thought the poor quality of the wrapping of the loom proved he'd been messing too much. The truth is this is how it left the factory. ![]() ![]() Click image to enlarge It seems the Near Field Sensor Module (NFSM) was not behaving well: ![]() Click image to enlarge |
Chaps, I'm considering a D300 or a P400, how easy is it to retrofit the shift paddles? --
Jtt74 Member Since: 20 Dec 2022 Location: Ascot Posts: 9 ![]() ![]() |
£250 to get ACC enabled, very tempted on my 2022 90 XS Edition. Anyone used these guys and any issues with dealers etc. Seems pretty low risk that they'd notice tbh? |
lrsg Member Since: 07 Dec 2021 Location: Cambridgeshire Posts: 19 ![]() ![]() |
I have done it. Got the ACC and Auto High Beam Assist activated. Highly recommended, took about 30 mins. Well worth the money.
I got it done today also, seems spot on
overlanding_defender Member Since: 15 Dec 2022 Location: Cobham Posts: 8 ![]() ![]() |
This post has been edited by the site administration team: commercial spam
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
Naks apparently you have to swap out the standard steering wheel for the same one that comes with the V8 I believe which has the paddle recesses https://www.powerfuluk.com/paddle-shift-up...wheel.html yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1469 ![]() ![]() |
Does any one else find ACC very brutal and not very sophisticated? Compared my XC90 it seems very crude.
tooslo964 Member Since: 25 Jun 2020 Location: Aberaeron Posts: 42 ![]() ![]() |
Yes we do too.
Find it unusable in most circumstances so just use the 'manual' cruise ![]() |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 275 ![]() ![]() |
You just need to know how to use it properly. Had a XC 60 before which worked slightly different but once you realise how it works I find it good. The reason for the difference is that it works off the road sign speed limits, so if you are doing say 60 on a motorway and select it it speeds up to 70. So I just select it and then use the speed select switch to reduce the speed to what I want . My Volvo selected the speed you were doing at the time which was slightly better. You can if you want go into senses and deselect speed sign part of it and just set it manually every time. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Bryce798 Member Since: 03 Mar 2023 Location: Illinois Posts: 1 ![]() ![]() |
Does anyone have a list of the CCFs that need changed to add ACC to a 2023 model?
