Home > My Defender > Fuji 110 LS3 build
Page 40 of 61 <123 ... 394041 ... 596061>
mcma1
Got the gear linkage adjusted to engage the tiptronic. You get a pretty average gear indicator with the shifter kit but rather than not use it i have put in somewhere I can at least see it, can get a nice digital one for the dash if I find it useful.... The tiptronic is excellent, no DCT but good changes. I find using the switch on the selector a bit awkward though as the gear stick is fully to the back and I dont want to add seat extenders so I dug out the old paddle shift kits I had from the last LS. These never really worked well as they used a bluetooth connection to the electronic shifter but I am going to try and make use of these and basically just turn it into a second switch.
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #887355 23rd Feb 2021 8:32pm
Linds Hanson
Always wondered how they worked without a clock spring! How are you planning to connect without BT?
Post #887473 24th Feb 2021 1:26pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
If the Bluetooth is a bit temperamental then maybe it would be best to go with a wired option. I've done many curly chords for rally/race with a quick disconnects to easily remove the steering wheel. 1989 90 4.3 V8
2012 L405 OF
2014 D4 HSE Lux (SOLD)
2015 90 HT (SOLD)
@d9o.mf
Post #887488 24th Feb 2021 2:15pm
mcma1
Sorry didn’t really explain. These paddle shifters are from my last LS which had a push button gear selector and then paddles via a Bluetooth module. I now have a simple rocker resistance switch on the top on the gear stick so I plan to just replicate another switch with the paddles. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #887572 24th Feb 2021 8:35pm
mcma1
Think I discovered the cause of the rough idle and occasional cut off, 10bar fuel pressure Shocked Shocked
LS engines should be around 52 psi. We fitted a new high flow pump into the tank and then a new 52 psi regulator so it would seem the regulator is shot. Have a new one on the way. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #887636 25th Feb 2021 5:32am
JOW240725
10 bar (145 psi)!! Shocked I'm surprised something didnt go pop! James
Instagram @suffolk_rovers
Post #887638 25th Feb 2021 6:23am
mcma1
Me too, we thought the first gauge was broken so added a bigger one which had the range. Luckily I have only run 100 miles but won’t go any further until it’s sorted. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #887643 25th Feb 2021 6:47am
Pickles
I might've missed it, but have we heard the sound of this V8 powered "work of art" working hard under load?
Pickles.
Post #887857 25th Feb 2021 9:52pm
mcma1
not yet Pickles...need to sort out the fuel pressure! got a nice new pump and regulator so that should be me back on the road.
Also decided to go down the simple route for the tiptronic, just moved the top of the gear knob, quick scan with the laser & reverse engineered it into a printed pod instead of a second cup holder, ideal location for me there. Just need to finish and paint it and then fit a new blank to the gear knob.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #888550 1st Mar 2021 9:02pm
Pickles
This thread is unreal, I've been involved in cars all my life, all sorts of cars, all sorts of engines/conversions etc, but I don't think I can remember such beautiful "more than professional" work, of such a complex & wide ranging nature, being carried out on a vehicle, & more particularly, where all the work has been designed, planned, & actually "done" by one person. Simply amazing.
Pickles.
Post #888562 1st Mar 2021 9:41pm
Something looks like there’s something giving birth on the centre console Very Happy
Post #888587 2nd Mar 2021 8:30am
JOW240725
Oh dear god Steve!!! Now I can't unsee that!!! Shocked Rolling with laughter James
Post #888590 2nd Mar 2021 9:18am
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Rolling with laughter Rolling with laughter Andy
Defender 90
Defender 110 XS
Cupra 290
Post #888594 2nd Mar 2021 9:25am
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Looking really good.
I need to buy the fuel system parts for my build any time now, any part numbers/advice/pics will be really useful
Post #888607 2nd Mar 2021 11:18am
mcma1
Shocked
Got this finished and working, new blank onto the gear knob also.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #888683 2nd Mar 2021 7:11pm
