Home > General & Technical (L663) > A video for the Caravanists among us |
Nitroneil Member Since: 05 Mar 2019 Location: Stirling Posts: 132 |
Spotted badge, it's a D240 90S D250 fuji and loving it.
19th Feb 2021 11:33am |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
That was very impressive |
19th Feb 2021 12:31pm |
What a strange review They've basically hitched up a caravan that's right on the limit of the capability of vehicle, which would never work in real life once you've added 'stuff' and your family! Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 20th Feb 2021 9:28am. Edited 1 time in total |
19th Feb 2021 12:49pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 |
The Offroad Zone RV (used) typically comes in around 2.5- 2.8T TARE, so that has likely been loaded up to the gills if it is at
3.3T. Ordering a Zone base off road for our lap of Australian they are generally one of the lighter Off Road Caravans by length compared to many of their competitors, mainly due to composite construction. Lucky we ordered the 5+2 Defender (have to listen to the wife more often ) it has a higher payload allowance on the rear axle, 1900KG rather than 1800KG.. They were not clear if they were using their airbag suspension, if so, i am assuming you can drop the hitch height by setting the van at a lower ride for on road.. yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
20th Feb 2021 4:40am |
Hmm, interesting. They didn't make it clear at all how they might have loaded the van.
Are you planning to remove the '+2' seats in order to take advantage of that extra axle load capacity? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
20th Feb 2021 9:31am |
defender_uk Member Since: 12 Aug 2011 Location: SW Scotland Posts: 197 |
Impressed. Caravan and cattle no issue then . 2020 First Ed 110.
replaced by 2021 250 110 Commercial Defender_uk |
20th Feb 2021 10:52pm |
not at this stage, when i order the Zone in the next month or so, i plan to go to their showroom and factory in Queensland and hopefully we can model and test a few options to gauge loading and see what the vehicle can take without breaking ADR, insurance and LR warranty clauses.
In regard to the loading i noticed they had the full jerry can holders, gas bottles, assume they filled the water tanks, those 3 will add approx 200KG to the Zone on average, so basically coming in around 3T before you pack anything inside, not unless of course it has a whole lot more options added to it, so far heavier TARE to start with. It is good they tried to make it more real world test.. yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
20th Feb 2021 11:13pm |
I was more impressed with how the D240 performed pulling 3 tonne trailer at ease and with total control. Just shows how good the 2.0L 4 cylinder engine is.
21st Feb 2021 12:45am |
^^^^ hoping the fuel consumption on mine is not much worse than they reported on the D240.
i suspect it will be though yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
21st Feb 2021 3:08am |
I was super impressed with how my 240 pulled a loaded cattle trailer of the field. Standard tyres, unfortunately, in mud & ruts mode, partially thawed muddy field, and not a single tyre slip. It just went as if on a flat piece of tarmac. 2020 First Ed 110.
21st Feb 2021 8:26pm |
landiepete Member Since: 31 Aug 2020 Location: Norf Posts: 18 |
I do own a larger caravan (8.89 m total length) with a 2500 kg gross weight. The issue with these things is not the weight, but the very large frontal surface causing air resistance (and thus required work) to exponentionalrise rise with speed.
Additionally, the stability at speed is primarily gouverned by the weight of the towing vehicle. I would not recommend anyone towing a 3.3 ton van at 60+ mpg (100 km/h) with a '90. Yes, it probably has all manner of electronic trickery to re-establish stability in case of emergency, but it is inviting disaster. Pete |
22nd Feb 2021 10:10am |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 |
A big part of stability at speed is trailer nose weight. If everything’s loaded correctly, I’d be happy to do 60+ in 2.2+ tonne 100” wheelbase Defender.
22nd Feb 2021 11:36am |
Your comment is ill informed and frankly dangerous. Yes, nose weight is important but, contrary to e.g. US vans, severely limited.
Secondly left-right weight of a van in Europe is seldom balanced. Your comment indicates to me you have very little experience pulling (large) caravans and as such you may consider refraining from commenting on the subject. |
22nd Feb 2021 11:42am |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
Saw lots and lots and lots of great looking combos in Aus last year. Not a lot pulled by LRs but managed to snap a pic of this one in Pemberton, WA.
Click image to enlarge Felt thoroughly inadequate in my little rental ASX. |
22nd Feb 2021 11:46am |
