Home > Td5 > Rear step model |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 |
NAS rear step and tow bar
16th Feb 2021 10:38pm |
It looks like a standard LR NAS step but there are several different ones available from different manufacturers and they're all very similar.
Is it one that you own or a specific one that you want to buy? You should probably be aware that if you're planning to use it as a tow bar then stainless bolts are not recommended because of their particular properties. Plated or even galvanised steel would be a better bet. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
17th Feb 2021 8:51am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3410 |
As above ^^^^. Ideally grade 10.9. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
17th Feb 2021 5:57pm |
TafkaP Member Since: 05 Jan 2021 Location: edinburgh Posts: 8 |
Thanks. It’s already fitted came with it. Think it was only fitted in November with new rear cross member.
Can grab some 10.9s out work easy enough. Might just paint them. Most it will take on tow bar is a bike rack. Hoping as the step pulls bar out futher rom spare I will be able to fit a rack with no hassle. |
17th Feb 2021 10:26pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
I have one of these NAS steps, and a 265/75 tyre on the spare.
I still need to use an offset bike carrier to clear the spare wheel. I have one of these: https://www.maxxraxx.co.uk/bikes-racks/exp...le-carrier My wheel is mounted to a swingaway carrier, rather than directly onto a door mount, but even still I don't think a vertical carrier will fit. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
18th Feb 2021 9:44am |
Mines is on a swing away too. Guess I’ll need to look at the maxis then. Cheers
18th Feb 2021 5:28pm |
