Home > Maintenance & Modifications > Td5 ABS sensors
bankz5152
Td5 ABS sensors
Given my constant and consistant ABS fault with the same side (7 sensors in 3 years)
Im thinking the fault lies elsewhere!
So anyone run a new wire from the SLABS unit to the sensor? Or are the any earths I can check.? Instagram @defender_ventures
Empire Tuning - Agent
Post #885266 13th Feb 2021 2:36pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
If the wiring in the loom side of the plug is faulty (which can give trouble) I would just get an abs sensor extension lead from a HGV factors and cut the other plug off at the ecu end and fit a couple of terminals to fit the ECU plug. Like I used genuine Wabco sensors for HGV trailers as they’re a damn site cheaper than ones for a Defender.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #885361 13th Feb 2021 8:01pm
