Home > Puma (Tdci) > 1st gear popping out
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Evening chaps , I getting a bit miffed with my first gear popping out at least twice a day !! , it happens loaded or unloaded , it’s not great when you have a big trailer on the back and you pull out of a junction , is there an easy fix ??? , it’s a 2011 UTW
With only 78 k on the clock
I’m even considering a recon gear box ?? , any thoughts .
Stew Thumbs Up
Post #885310 13th Feb 2021 4:51pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I can't help you there bud but I've hardly used 1st, even towing caravans and horse box's, always pull off in 2nd
Post #885347 13th Feb 2021 6:57pm
stew 46
Not so easy with 3.5 t on the back if you want your clutch to last Thumbs Up
Post #885348 13th Feb 2021 7:00pm
LR90XS2011
there is a tread on here somewhere regards the same issue and setting up the gearbox intents and lever to stop it happening. DEFENDER 90 TDCI XS,
Post #885395 14th Feb 2021 6:51am
