Home > Technical > Shock lengths for a standard height shock for a 110 |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2270 |
Set your new shocks to the same length as what is fitted at the moment in situ and then measure how much compression and extension you have either side of that length.
That should give you a good idea. HTH MO The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
12th Feb 2021 2:20pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
Thanks for the thought but not sure that tells me the full extension length of the damper on the vehicle to be honest. It just says how much more travel the new one has over the current position. It's the internal shaft length of the fitted one I can't tell to figure out the free length of a standard and +2 length fox shock.
Might just whip one off and check. |
12th Feb 2021 4:34pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
16.1" for the purple RKB 101111's fitted to the USW
This site will help you work it out ...nevermind i can't work out how to link with a Macbook |
12th Feb 2021 7:39pm |
http://www.red90.ca/rovers/springinfo.html
Worked it out... |
12th Feb 2021 7:41pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
If you want to sell it all on.... just let me know! Don't tell Badger James
12th Feb 2021 7:45pm |
Don't forget Matt, the USW sits high at the rear regardless rather than your front sitting low if that makes sense? I've got Snatch bullbar which weighs 30 odd kg's, a spare wheel ( 30kg?) and some braces on the front and mine doesn't sit lower at the front at all with probably 75kg extra at that end. |
12th Feb 2021 8:06pm |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 56 |
Just popped down to the garage to measure some genuine LR new take offs, never fitted.
RNB501450 - 665mm extended, 450mm compressed (pin to pin) RPD501000 - 650mm extended, 445mm compressed (pin to eye) All measurements are taken from extreme end to end, not the centre of the eye etc. |
12th Feb 2021 8:27pm |
Thanks everyone, really appreciate the thoughts and Piggy thanks for going down and measuring for me.
Will have a look today and see what I can measure. Badger, ref the height, the whole spring question is utterly baffling. Basically.... 110 USW, carries an 8274 on the front on twin batteries, and has an SD external cage. So we're talking maybe 75-100 extra nose weight and I'm guessing about 150-200kg rear weight with the stuff that's always in it, drawers etc. I'd like it to sit level, but not rear matching front, front matching rear, or about standard Height +1 maybe. I guess I need to look up the spring rates using the link of what I've got, and the free length, and then look for something that will level out the front to the back a bit better. I'm planning air helpers for the rear when it's carrying heavy loads so it just needs to sit fairly level at standard rear height plus a bit maybe, and the front to look right Vs that.l without the dragster look. Trouble is even if you ask people for their springs and the attitude it provides, you don't really know the weight in the vehicle and how old they are.... |
13th Feb 2021 8:18am |
